Dead ASUS ROG G14 (GA401)
  • jacobtc
    replied
    Re: Dead ASUS ROG G14 (GA401)
    Originally posted by mon2
    BATPRES is an active LOW signal. So when the battery is present, this pin should be low = 0 volts.
    Remove the battery and this voltage should become a logic high value. Confirm it.
    Measure the voltage to ground of each pin on the battery connector.
    Post all measurements.
    BATPRES is still low (0V) without battery.
    All battery pins on board measure 0V.
  • mon2
    replied
  • jacobtc
    replied
    Bumping this thread in hopes of support for another thing wrong with this.
    I finally received my battery, however Windows does not detect it charging at stays at 1%.
    Battery norminal voltage is 15.4V, but is currently stuck at 15.1V and does not increase. Checked BQ, ACDET is 2.7V, ACOK is 6V, however BATPRES is 0V Is this a faulty aftermarket battery, or is something else wrong?
  • jacobtc
    replied
    Not advisable to "unlocking" batteries.Often the battery management PWM goes into protection when you dis connect cells. Need programmer to unlock that protection. I tried it on 2-3 batteries in my spare time and was able to fix only one out of three. The cost,energy and time simply dont make any sense. I just did it once for my own experience sake.
    Alright, it just feels wasteful to throw out good cells. This is the third time doing it.
  • mcplslg123
    replied
  • Sephir0th
    replied
    Unfortunately not. I don't do that at all since this is only hobby for me. it just isn't economical for me tonsource a suitable device along with the mess to replace cells and all these things. Maybe someone else can help for this question.
  • jacobtc
    replied
    Originally posted by Sephir0th
    Good to know, the thing you pointed out in the schematics is just feedback Reference voltage and has nothing ro do with the actual output of the Phase anyway.
    Now I'd be happy if the issues stop from now on...
    Got Windows installed, and everything seems to work but the battery, so I will have to look into that... Have you had any luck unlocking batteries?
  • Sephir0th
    replied
  • jacobtc
    replied
    Great success! New BIOS fixed it! Got it all stripped down to test, but it outputs display!
    Now to figure out if the battery is salvable. I've had three generations of these G14, and common for them all is that they lock/kill the battery if anything happens with the board...
  • jacobtc
    replied
    It is GND and the "diode" is probably a Capacitor. Maybe we are on something with the 1.2V there, though. Detailed inspection of the circuit necessary, but not today (at least for me^^)
    Is this the expected voltage for VRAM described in the schematic? Page 78.
  • jacobtc
    replied
    I strongly suggest to forget this area immediately. That's for battery charging and has nothing to do with your issue. Voltage without battery present is useless and meaningless.
    Edit: except you measure a short to GND at the coil.
    Alright
  • Sephir0th
    replied
    Originally posted by jacobtc
    Alright, but I am guessing 0.2V isn’t normal either, right?
  • jacobtc
    replied
    Alright, but I am guessing 0.2V isn't normal either, right?
  • Sephir0th
    replied
  • jacobtc
    replied
    Im sorry if this is a stupid question, but is this side ground? It measures 0.12 ohm, but the ?diode? Right above measures 20V on one side and 0V on the other… It just seems like the area marked with blue does not turn on, all measure 0-0.2V when plugged in and does not change when power button is pushed.
  • jacobtc
    replied
    unfortunately 35 Ohms are perfect, so still no clue and i guess when you measure again, the 1.35V +FBVDDQ is coming up there?
    i have not much hope left for this device to be honest. Maybe, to rule out a corrupot BIOS will be worth a try.
    1.2V is measured on both coils.
  • Sephir0th
    replied
  • jacobtc
    replied
    Neither boardview nor schematics seems to match exactly for this board. Maybe someone can enlighten me regarding this issue.
    However. Neither 0 Ohms, nor O.L. is a normal value for +FBVDDQ and i'm pretty confident, that's the rail we're dealing with.
    So please check again. Try to exclude some kind of contact issue with your probes, maybe by measuring each coils between both pads (they should show short ofc).
    Yeah, the boardview and schematic is for a different model, but was the closest I could find. I just checked from a grounding point to both sides of the coils...
    EDIT: You were right, I get 35ohm on both sides on both.
  • Sephir0th
    replied
  • jacobtc
    replied
    I'm concerned about these two right now. Double-check voltage first. Then remove power and check resistance to GND at any coil, any side.
    I have the feeling there could be a issue with the +1.35V supply for VRAM.
    Is it possible to share the schematics or is it already shared somewhere and you can share the link?
    Edit: somehow missed them completely. Thanks for pointing that out for me again...
    Both measure OL, no shorts.
    EDIT: I tested again, and I do infact get 1.2V on the two coils, just very shortly, which is why I missed it last time. Also, after removing the heatsink and fans, the laptop turns off faster (3-4 sec), I'm pretty sure it doesn't overheat, as the CPU and GPU is only slightly warm.
    Sometimes the laptop stays on (light on) but no voltage on coils.. Very weird.
  • Mabot17
    ASUS gaming laptop GL704GV GPU DEAD SHORT
    by Mabot17
    Hello i need help to fix this laptop,at least a discrete to UMA conversion if it's possible.
    i took a photo of what i found,NVIDIA gpu side is 100% shorted as i desoldered power line coils and mosfet side is ok.
    Even without coils laptop still not power on.Main power rails,bios,1v,3,3v and 5v are present...
    05-10-2025, 11:04 AM
  • ktmmotocross
    Asus UX433FAC - batery dead after short on VIN rail
    by ktmmotocross
    Hello.
    Have this Asus UX433FAC that came with shorted mosfet on main power rail. After replace laptop works ok, but battery is dead. Laptop show charging but voltage on battery is 0.2V. when remove battery voltage on battery connector goes to 8.5V, but when connect battery again it goes down to 0.2V.
    can that short shorted battery? batmon show that battery is full at 80%
    12-29-2022, 12:06 PM
  • OOF DIO
    ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
    by OOF DIO
    (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
    (Had 3 problems, now just 1)
    I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
    I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
    I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
    04-19-2025, 05:03 PM
  • jkucukov
    Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
    by jkucukov
    I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
    During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
    02-05-2025, 09:27 PM
  • Beton
    Finding a dead short component
    by Beton
    Hi guys!
    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
    I have a bench PSU and if I try to inject voltage the voltage...
    12-10-2021, 01:05 PM
