Clear CMOS on unowhy Y13 Ultrabooks on motherboard
  • reformatt
    • Feb 2020
    • 1401
    Re: Clear CMOS on unowhy Y13 Ultrabooks on motherboard
    Direct read from a chip on a board rarely works, so you'll have to remove it. I think in that kit, they give you a small PCB to solder the chip onto. You have to use hot air for WSON8 EEPROM's.
    There is another adaptor I use that doesn't require soldering if you are interested. You have to wick the pads clean usually and clean up in IPA before good contact is made though.
    https://www.aliexpress.com/item/1005...8daDVlmaC&mp=1
    • highsnoop
      • Feb 2023
      • 21
      • IDF
      Yattaaa
      I managed to solder directly on the chip after one hour of fight.
      I got the dump of my bios (I doing it twice time to compare result and the both files are identical).
      Does the parameter to change in the file is my picture proposal (A Vs B)?
      Thanks again for your help and hope my story can be help anyone in this adventure
      or if someone can provide the same bios version (i don't know what is it) without password
      Bios - https://www.badcaps.net/forum/showthread.php?t=115849
      Last edited by SMDFlea; 02-18-2023, 03:16 AM. Reason: Bios moved to "Bios requests ONLY!" sub forum
      • YourBlamp
        • Feb 2023
        • france
        hi highsnoop
        I also try to dump and put another bios in an unowhy.
        What tool did you buy to do the trick?
        Thanks in advance.
        • highsnoop
          • Feb 2023
          • 21
          • IDF
          Originally posted by YourBlamp
          Salut highsnoop
          J'essaye aussi de dumper et remettre un autre bios dans un unowhy.
          Quel outil tu as acheté pour réaliser la manip ?
          Merci d'avance.
          CH341a + adaptor 1.8v
          For the driver + tools : Driver+tools
          Impossible de lire la puce avec la pince, j'ai directement souder (voir photo) les pin 1 2 4 5 6 8
          Attention ce n'a pas été facile car c'est très petit et la solution avec l'air ne pas convaincu avec le nombre de petite résistance proche du chip.
          Pour l'instant je suis toujours bloqué et en attente d'un modification de mon Bios ou bien d'un bios compatible pour le remplacer
          Impossible to read the chip with the pliers, I directly solder (see photo) pins 1 2 4 5 6 8
          Attention it was not easy because it is very small and the solution with the air does not convince with the number of small resistance close to the chip.
          For the moment I am still stuck and waiting for a modification of my Bios or a compatible bios to replace it
          • highsnoop
            • Feb 2023
            • 21
            • IDF
            For the expert
            It's the same model of this thread https://www.badcaps.net/forum/showpo...91&postcount=2
            So can i put this bios on my mine without problem ?
            • highsnoop
              • Feb 2023
              • 21
              • IDF
              #26
              With the AMIBCP tools i read my dump
              BIOS Date: 10/28/2020 19:55:13 Ver: 3BAPS05
              American Megatrends Inc.
              V0.5.0_P1S0M2E0F3L6B0T0P2G00A0U0D601_ENE
              10/28/2020
              Can i set option directly from this tools or can i do it with another one ?
              • highsnoop
                • Feb 2023
                • 21
                • IDF
                #27
                I flashed this bin file whose it the same version of mine.
                I checked, erase, write , read and save it to compare to the original and no difference.
                I desoldered all, check short circuits
                Start the notebook and same result "Power led with black screen"
                No idear....
                • dwardo
                  • Aug 2023
                  • France
                  #28
                  I also am facing the same black screen as I wanted to install Manjaro Linux using a USB key and modified
                  * / Setup / Chipset / Southbridge / OS Selection from "Windows" to "Linux"
                  * / Setup / Boot / USB Support from "Partial Initial" to "Full initial"
                  after save & exit got the black screen...
                  So I ordered my ch341a... am waiting and discovered AMIBCP
                  Have you tried opening your own dumped "borked" bios bin file in AMIBCP, changing the Setup/Boot/Fastboot parameter (cf. attached screenshot), saving under new name and flashing the modified bios ?
                  Bios contains the Serial Number of the Y13 computer (cf. attached screenshot)... so maybe its not just information and checked agains someting/somewhere and that's why flashing someone elses Bios is not working for you when you flash it...
                  • glovecaps
                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                    by glovecaps
                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                    11-25-2024, 04:23 PM
                  • Docus
                    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                    by Docus
                    Hi everyone 😀,
                    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                    1. I already own the exact same model, but its plastic chassis is badly damaged.
                    06-10-2025, 04:24 PM
                  • Archimedes
                    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                    by Archimedes
                    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                    Fans are spinning. Blindly could install windows11 and got the device manager...
                    07-30-2024, 05:14 PM
                  • dragon3x
                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                    by dragon3x
                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                    power on.
                    Here are some examples :
                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                    switching supply area).
                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                    than 6.3 V.)
                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                    I replaced capacitors with aluminum-polymer.
                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                    03-21-2025, 02:46 PM
                  • dhenion
                    Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                    by dhenion
                    I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                    The original board was:
                    ASUS X510UNR REV 3.0 A
                    The replacement board is:
                    ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                    It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                    01-30-2024, 01:45 PM
