HP laptop model 17-y018cy Halt on boot
  • MrRoo
    • Jan 2023
    • 6
    • Spain
    I have a 6-year-old HP laptop model 17-y018cy
    on every boot "product information not valid" is shown and that the product name, serial and system board numbers are missing and press enter to continue, I have contacted HP Uk but they can't help me.
    Anyone know of a way of stopping it showing or entering the information required as it bugging me
    Thanks in advance Andrew
    • 31204
    Re: Halt on boot
    there are tools to set that, i think it's stored in the bios.
    try searching stuff like "hp bios configurator"
    is it a replacement board from ebay in it?
    • reformatt
      • Feb 2020
      • 1472
      Re: HP laptop model 17-y018cy Halt on boot
      Replacement boards from HP come without that info, and the tech is supposed to fill it in after installation. They have their own tools to do it I believe but you can use the Bios Configuration Utility.
      https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
      BTW, HP had dropped support for this utility in favour of some new scripting tools. But there were about 4 scripts to do the job this tool provides in one package. So all mention of them dropping it seems to have gone!
      Most of the info you need will be on labels on the motherboard. Some will be on or around the RAM sockets, or other parts of the board. You can write this stuff in with the utility, it's pretty straightforward. Usually what I do is dump the entire contents to a file, edit and reimport it.
      BIOSConfigUtility64.exe /GetConfig:"Bios_settings.txt"
      Open the txt file, edit the data you need, save it, then reimport. You might need to change the permissions for the SP143621 directory to allow you to save changes etc.
      BIOSConfigUtility64.exe /SetConfig:"Bios_settings.txt"
      If you get an error that the MPM isn't locked, you set the Manufacturing Programming Mode to Lock via the /SetValue command. Most of this stuff is from memory and some things may have changed since I last did it.
      BIOSConfigUtility64.exe /setvalue:”Manufacturing Programming Mode”,”Lock”
      • MrRoo
        • Jan 2023
        • 6
        • Spain
        Thank you all so much I have the tools now! Just got to work out how to use them
        • MrRoo
          • Jan 2023
          • 6
          • Spain
          I have tried to run these tools but have not been able to get more than a a quick flash of a terminal window or error messages when running the commands you have kindly given me
          I opened the laptop and found a label inside the case with this number, would this be the MB No 46008c0050011801DHHA10021216
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            Hi here you have video from guy who explains it good
            https://youtu.be/ttP1aL0u8Ws
            Watch this and you know how to fix your laptop.
            • MrRoo
              • Jan 2023
              • 6
              • Spain
              Thanks, I don't have the lock message that he talks about but I get the idea now
              I need to run in a WINPe environment and perhaps unlock first then rewrite the text relocking at the same time. Do you think that will work.: confused:
              • Zubi
                • Dec 2022
                • Romania
                it works in WINPe
                • MrRoo
                  • Jan 2023
                  • 6
                  • Spain
                  I have tried to follow the instructions given but I've come unstuck with this file
                  I have downloaded it and now find I can't change the read only mode
                  I have tried using the CMD icacls d: \file name /grant:f but it returns to Read only as soon as I unlocked it and then reopen it's read only again. I'm using this a PE environment so surely, I should have control
                  any ideas gratefully received
                  • Loki_Fido
                    BIOS for Microsoft Surface Laptop 7 - Model 2036
                    by Loki_Fido
                    Hi ya folks,
                    Attached is the BIOS from a Microsoft Surface Laptop 7 - Model 2036
                    As of right now i am unable to confirm whether this BIOS dump works or not.
                    But i will update soon. Hopefully in a day or two.
                    Given that no one else uploaded any BIOS backup for this laptop, I thought i might as well start a new thread and upload what i have.
                    Microsoft Surface Laptop 7th edition
                    Model 2036
                    SN 0F3CPFB24153HH
                    Remember, If you tried to read this chip with CH341A, this device will not identify this chip for you.
                    Both ASProgrammer...
                    09-11-2025, 04:00 AM
                  • TurcoLoco
                    I Would Like To Fix This HP Laptop, Model:15-dy5058cl
                    by TurcoLoco
                    Hello all,
                    My first post on this forum. Looking at the "Beginner's Guide", I am in the second group even though I'd like to fix this laptop so I can donate it to someone.
                    I am a computer tech but very new to electronics repair iow, a total noob but in the process of learning, hence posting here. The laptop was donated to me by a client.
                    It is a couple of years old 15" HP Laptop, Model:15-dy5058cl, Prod ID: 8L5X9UA.
                    The issue: Charger is detected but doesn't charge the battery.
                    Laptop won't power on without the battery (not sure if this is by...
                    06-26-2025, 04:54 PM
                  • Calidebear
                    Dell 3537 laptop doesn't boot without embedded display.
                    by Calidebear
                    I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
                    So checked the schematics to bypass this issue.
                    Found something but I don't know how to read this schematics.
                    Dell 3537 mobo 9982p rev 3
                    Schematics attached,...
                    03-29-2025, 11:37 AM
                  • Luke Anders
                    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                    by Luke Anders
                    A few details about the laptop itself:
                    Name: Lenovo Legion 5
                    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                    BIOS Version: GKCN60WW
                    EC Version: GKEC65WW
                    Serial Number: PF39AQ7Z
                    Board Model: NM-D562 Rev 3.0
                    RAM: 16GB Installed, DDR4 (brand new)
                    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                    I bought this laptop recently from eBay as a faulty device....
                    10-12-2024, 05:13 AM
                  • insomniacno1
                    Thinkpad L540, won't turn on unless I switch ram
                    by insomniacno1
                    This is a very weird problem and super annoying, so if someone who has experience with this, can explain why this is happening, then I will be grateful😁
                    This happen usually when the laptop has been moved. from one room to another OFF charger for some hours, but has also happened when laptop has been shut down and left ON charger over night, and not moved :
                    I turn on the laptop normally by pressing the power button briefly, then power comes on and Power LED and Fn LED turn ON/OFF constantly (no post and no beep codes)
                    If I(and this is my only option at this point),...
                    09-29-2025, 05:58 AM
