A1502 fan not turning on
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I very rarely work on macs... Received this mac, i dont know history...It seems everything is working but i have no fan spinning...I tried different fan but same thing. The problem is on FAN_RT_PWM signal... there is no voltage. On connector J6050 pin 1 and 4 voltage present, but pin 2 nothing. I checked q6060 and on r6061 the resistence seems ok. Tried nvram reset and smd reset but same thing. Also, i used the thermal camera and temperature goes to 85 C on CPU in several minutes but fan is doing nothing.
    I have only two more ideas..either q5159 or something associated with cpu thermal sensor is dead or U5000 dead!?
    Any other ideas?
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: A1502 fan not turning on
    On 820-4924 fan starts spinning only after CPU gets burning hot. If it's not throttling it's fine.
    • myth77
      • Feb 2017
      • 380
      • Croatia
      So, you are saying 85 C is not enough for apple to turn fan on? Lol
      • mon2
        • Dec 2019
        • 14022
        What is the voltage to ground of SMC_FAN_0_CTL ?
        • myth77
          • Feb 2017
          • 380
          • Croatia
          0 vol
          • reformatt
            • Feb 2020
            • 1401
            Just run diagnostics by pressing D during startup. Fan and tach is tested during the tests. Report back if you have an error.
            Apple don't mind running the CPU's hot.
