A1502 fan not turning on
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I very rarely work on macs... Received this mac, i dont know history...It seems everything is working but i have no fan spinning...I tried different fan but same thing. The problem is on FAN_RT_PWM signal... there is no voltage. On connector J6050 pin 1 and 4 voltage present, but pin 2 nothing. I checked q6060 and on r6061 the resistence seems ok. Tried nvram reset and smd reset but same thing. Also, i used the thermal camera and temperature goes to 85 C on CPU in several minutes but fan is doing nothing.
    I have only two more ideas..either q5159 or something associated with cpu thermal sensor is dead or U5000 dead!?
    Any other ideas?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: A1502 fan not turning on
    On 820-4924 fan starts spinning only after CPU gets burning hot. If it's not throttling it's fine.
    • myth77
      • Feb 2017
      • 380
      • Croatia
      So, you are saying 85 C is not enough for apple to turn fan on? Lol
      • mon2
        • 14666
        What is the voltage to ground of SMC_FAN_0_CTL ?
        • myth77
          • Feb 2017
          • 380
          • Croatia
          0 vol
          • reformatt
            • Feb 2020
            • 1500
            Just run diagnostics by pressing D during startup. Fan and tach is tested during the tests. Report back if you have an error.
            Apple don't mind running the CPU's hot.
            • richiekotzen
              A1502 - 820-4924-A - light green and then orange without battery - Not turning on - CPU warm,3 beeps
              by richiekotzen
              A1502 820-4924-A, e, no liquid, stop working suddenly. Yesterday, I've plugged magesafe, light green and then orange without battery,3 beeps, not turning on, CPU warm and at some point fan was spining but nothin on screen, .. no chemie.
              12-17-2024, 01:15 PM
            • sheffieldyorky
              ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
              by sheffieldyorky
              Hey there people
              While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
              This is what I tried, but not in any order.
              Google
              YouTube
              BIOS
              Command Prompt (administrator privileges)
              On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
              10-25-2025, 02:22 AM
            • odie34
              Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
              by odie34
              I am a hobbyist (not a professional) so please be gentle...
              I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
              I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
              02-18-2024, 09:11 AM
            • ictc
              Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
              by ictc
              I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
              Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
              The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
              02-25-2025, 12:15 PM
            • kotel studios
              ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
              by kotel studios
              Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
              Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
              I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
              12-14-2024, 10:48 AM
