I got a problem with my Dell Presicion 7710
  • moxm98
    • Feb 2022
    • 6
    Hello, I would be happy if someone could help me! To me first: Im from Germany and my English is therefore not perfect! nvm..
    I got a problem with my Dell Presicion 7710 with Motherboard No. LA-C551P REV2.0.
    NO POWER!
    I have done every ordinary thing, such as resetting CMOS and leaving the RTC battery out for a while. It is completely dead, no light, nothing. The powersupply outputs 19.5V and the DC plug measures fine. I have inspected the board, and nothing seems to be obviously damaged, no burn marks, and no apparent water damage. The next step is to check for shorts, however, how would I go about doing that? I don't have a bench powersupply, so it is difficult for me to inject voltage and check with alcohol evaporation etc. I measured the voltage on the JPB1 (ON/OFF-button) and on Pin1 i got 3V. On pin 2 i should get 5V, but theres missing -> 0V. So i looked up in schematics and followed the track to 5VALWP. And the 5VALWP comes from the PU101 with is the powercontroller maybe? So measured the voltages on the PU101 pins and realized that the 5V were missing. The 3V were there, but no 5V.
    Here are my measurments on PU101:
    Pin 1 = 1.12V
    Pin 2 = 0V
    Pin 3 = 3.13V
    Pin 4 = 0V
    Pin 5 = 0V
    Pin 6 = 3.13V
    Pin 7 = 0V
    Pin 8 = 0V
    Pin 9 = 4.6V
    Pin 10 = 0V
    Pin 11 = 0V
    Pin 12 = 19.35V
    Pin 13 = 5V
    Pin 14 = 0V
    Pin 15 = 0V
    Pin 16 = 0V
    Pin 17 = 4.6V
    Pin 18 = 0V
    Pin 19 = 0V
    Pin 20 = 3.13V
    Anyone willing to give a bit of guidance?
    Schematics and boardview: https://www.badcaps.net/forum/showthread.php?t=115320
  • Sephir0th
    • Oct 2020
    • 1289
    Re: I got a problem with my Dell Presicion 7710
    You have likely a short to GND at one of the ALW rails. Remove power, meter in resistance to mode. Resistance to GND of PU101 Pin8 and Pin 18?
    FairRepair on YouTube
    • moxm98
      • Feb 2022
      • 6
      On Pin 8 the resistance floats between 4k-8k ohms and on Pin 18 floats between 20k -21k ohms.
      • Sephir0th
        • Oct 2020
        • 1289
        Interesting. Identify PL101 and PL102. Meter in voltage mode. Red probe already the coil, and black probe already to GND before pressing the power button. Any spike to catch? Do this with both coils.
        Another question would be whether the charger is known good and of correct wattage. Can you clarify?
        • moxm98
          • Feb 2022
          • 6
          On PL101 we got 4V and no difference with pressing power button. On PL102 nearly 0V. When i plug the charger in, PL102 goes from 0V to 14,5mV.
          Its the original charger from Dell with 240W 19,5V -> 12,3A.
          Btw: thanks for your help!
          • Sephir0th
            • Oct 2020
            • 1289
            Unfortunately we have a Problem now. At least one of your measurements is confirmed wrong, since PL101 and PU101 Pin 8 have continuity.
            You have to sort that out first before we can continue. And this applies to any measurement you have done so far. Otherwise the assistance here would misleaded and the case probably end in being a no-fix
            • moxm98
              • Feb 2022
              • 6
              Yep.. measured again and now we got both nearly 0V. PL101 ist fix at 0V. PL102 stays stabile at 3mV.
              could that fit?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Resistance on pin8/18 is healthy. You have both 3/5V LDO as well both the enable's are present on pin6/20. So replace PU101.
                • Sephir0th
                  • Oct 2020
                  • 1289
                  Agree. I'd suggest tonreplace all 4 related mosfets too. If nothing helps, deep troubleshooting of this circuit is necessary. Also check whether the controller is getting hot by any chance.
                  • rediii
                    h???, spurrrn
                    • Mar 2018
                    • 501
                    • somewhere in europe
                    i have had a similar problem with a toshiba protege with a mec ec. in my case the measurements were identical. i had to reball the mec ic and the machine worked fine again. replace 3 V/5V ic and mosfets first, like the others suggested. maybe it helps. good luck!
                    • moxm98
                      • Feb 2022
                      • 6
                      okey, i´ll order some of these ic´s. I have one notebook (MB No.: X756UXM) as replacement for some components and I found a ic chip similar to the UP101 (marking says: uP9003Q). Can i use it?
                      • rediii
                        h???, spurrrn
                        • Mar 2018
                        • 501
                        no, you should replace the chip with TPS51285B
                          DELL Precision 7710 Mobile workstation 7000 Specification for Upgrade or Repair
                          This specification for the DELL Precision 7710 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7710 boardview and 7710 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                          09-06-2024, 12:25 PM
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • Akhlz001
                          by Akhlz001
                          09-20-2025, 07:15 PM
                        • master3112
                          by master3112
                          07-29-2025, 01:55 PM
                        • Aurora256
                          Dell Precision 7710
                          by Aurora256
                          My Laptop Dell Precision 7710 suddenly not booting. Battery is flashing. There is an indication that there is a power input.
                          Hoping everyone to share your expertise.
                          Thank you
                          03-12-2024, 03:09 AM
