MacBook Air M1 820-02016 No Power 50mA
  • kuba2102
    • Jan 2020
    • 42
    • Scotland
    Hello group. The Macbook was flooded and someone was already tinkering with it, it doesn't show any signs of life. The track pad was also affected by water, but didn't find any shorts. The charger initialises usually 5V and about 300mA and at 20V 20-50mA, voltages as below:
    PP3V8_AON_VDDMAIN - 3.8v
    PPBUS_AON -12.3V then 12.0V and going down and cycles
    PPVDD_SOC_S1 - 0.62v
    PP1V8_S2 -1.8v
    PP2V5_AWAKE_NAND - 2.58v
    PP1V25_S2 - 1.22v
    PP3v3_S2_UPC - 3.3v
    PP5v_S2 - 5.2V
    PP3v3_UPC0_LDO - 3.3v
    PP3v3_UPC1_LDO - 3.3v
    PP1v5_UPC0_LDO_CORE - 1.59v
    PP1v5_UPC1_LDO_CORE - 1.59v
    The SOC heats up to about 20 degrees. Trying to force DFU through the jumper does nothing. Is it a faulty SOC?
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
  • Flasman90
    Macbook Pro DFU Restore Issues
    by Flasman90
    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
    08-30-2025, 10:27 AM
  • tobeend
    Bypass mdm macbook m2 ventura
    by tobeend
    1. RESET MACOS WITH IPSW
    a. Power off MacBook, press and hold the power button to enter Recovery
    b. Open Disk Utility, remove Macintosh HD
    c. Reboot, connect to the network to Activate Mac.
    d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
    d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
    e. Release the other keys, but keep holding the Power key for another 10 seconds
    f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
    05-26-2023, 07:18 AM
  • SarcasticOP
    General question about MacBook power rails for repair.
    by SarcasticOP
    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
    • PPBUS_G3H (12.6V-12.8V)
      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
    • PP3V42_G3H (3.42V)
      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
    • PPVRTC_G3H (3.3V)
      • This
    12-12-2024, 05:50 PM
    Acer Aspire A517-52G-50MA + Extended Service Plans Notebook 5 Specification for Upgrade or Repair
    This specification for the Acer Aspire A517-52G-50MA + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52G-50MA + Extended Service Plans boardview and A517-52G-50MA + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
    09-07-2024, 02:20 AM
