XPS13 all rails present, continuous shutoff cycle
  • survivalbloke
    • Aug 2021
    • 268
    Re: XPS13 all rails present, continuous shutoff cycle
    Originally posted by Sephir0th
    Since we still know to less about where it is Stuck, i'd continue with a overview which power rails are where present in the Brief moment. This means to measure voltage of each coil and share the values, maybe written in a picture of the actual board.
    Will do, thanks!
    • survivalbloke
      • Aug 2021
      • 268
      I'm posting a pic with voltage readings. Thanks!
      • Sephir0th
        • Oct 2020
        • 1262
        So everything till 1.05V is up and running. The PCH should do its job from here, but it obviously doesn't. Question is ofc, why.
        What resistance to GROUND do you measure at the coils which shows voltage?
        FairRepair on YouTube
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Can you post a larger pic? I'm having difficulty in reading what you wrote. Getting old perhaps.
          • survivalbloke
            • Aug 2021
            • 268
            See attached, better photo.
            • survivalbloke
              • Aug 2021
              • 268
              That was a really bad picture, sorry. Please see the new, better pic.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                PL601 is most likely the ram coil and its not having any voltage. Check the PWM for S3/S5/Ton pins. When you turn on,do you get any voltage there?? What about the 1.8V/2.5V rail?? Are they coming up?
                • survivalbloke
                  • Aug 2021
                  • 268
                  I suppose I'll need an oscilloscope to check PWM? Also I don't know where to measure those. Lastly, I don't know where to measure for the 1.8V and 2.5V.
                  I realize this is really far beyond my experience level, but I'm learning, and I thank all of you.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    #29
                    mEASURE VOLTAGE ON PIN 1/2/10/14 OF PU600.
                    1.8V can be measured at Pin1 of PU800 or on PL801 coil itself.
                    I think 2.5V rail is not used here.
                    All these voltage has to be measured after turning on the mb.
                    You need needle sharp probes to measure them.Be careful not to accidentally short between pins.
                    PS: Oscilloscope is a better option but we can get an idea with multimeter as well.
                    • survivalbloke
                      • Aug 2021
                      • 268
                      OK, thank you. on PU600:
                      1 - 0v
                      2 - 0v
                      10 - 8.9v
                      14 - jumps to 1.7v then drops back to 0v
                      1.8v present at PL801
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        #31
                        Pin14 Voltage must be stable. I've not gone through the datasheet of this IC but usually VCC is 3V or 5V. What is the exact resistance on pin14??(no power attached). Is there continuity between PC606 & PC607(pin1 of both caps)?? You dont have the enables for this ram regulator-so cant expect any output.
                        AS per your measurement, you have missing RUN_ON_P as well as SUS_ON_P.Do you have RUN_ON_EC?
                        • survivalbloke
                          • Aug 2021
                          • 268
                          Pin 14 = OL
                          Pin 1 PC606 to Pin 1 PC607 = .7ohms
                          RUN_ON_EC = I get a brief(less than 1 second) 1.9v, then back to zero each time the board tries to power on.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            #33
                            This mb SIO is in BGA form-so cant troubleshoot much. I've not much to suggest further. maybe other experts here can help.
                            • survivalbloke
                              • Aug 2021
                              • 268
                              Hey, I ended up just replacing the board, but I wanted to stop back here and thank you all for the help.
                              • skwarszczow
                                Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                                by skwarszczow
                                This is my first post on the forum
                                I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                                Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                                Before completing the purchase, we decided to erase...
                                03-23-2025, 06:04 PM
                              • SarcasticOP
                                General question about MacBook power rails for repair.
                                by SarcasticOP
                                I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                • PPBUS_G3H (12.6V-12.8V)
                                  • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                • PP3V42_G3H (3.42V)
                                  • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                • PPVRTC_G3H (3.3V)
                                  • This
                                12-12-2024, 05:50 PM
                              • iMuhtaseb
                                A1502 2015 820-4924 no power
                                by iMuhtaseb
                                board came in cleaned up from a previous technician.. after examining the board visually I've seen some work done on the EFI/firmware..
                                I've taken the chip out and it reads ok on Mac EFI Toolkit, I can read the SN and other information normally..
                                I have taken a look into the board and I could not find anything suspecting.. I tried to look for corroded chips or corroded caps even to see if there's any areas damaged by liquid and I could not..
                                I've taken some measurements:
                                PPBUS 12.6
                                PP5V_S5 present
                                PP3v3_S5 present
                                S4 rails when...
                                06-29-2024, 05:29 AM
                              • flusher
                                Apple MBP16" A2141 820-01700 PMIC power cycles no boot no shorts
                                by flusher
                                Bought myself a project thing. Apple MBP16" A2141 820-01700
                                No shorts, no visible waterdamage.
                                Dead. no history.
                                All USBC ports do 20V and charging battery.
                                If you plug battery/charger PPBUS is 12.6v and all power rails like RTC, 3v3, 5v etc are present. U7800 PMIC all voltages are present APART from PPVCCPRIMCORE_PRIM_REG (not sure if it has to be present at this stage?! resistance is 40 Ohm). SSD 2.5, 0.9, 1.8 are present on both wings. Charger meter shows 30ma or something like this on charged battery.
                                But what PMIC does is that it power cycles(dropping to...
                                02-21-2025, 03:12 PM
                              • luna69
                                ideapad 320 14ikb - no power, all rails present
                                by luna69
                                Good day! I'm trying to troubleshoot an nm-b242 board. The laptop powers on by default when ac is plugged in. The power button responds and I can turn the laptop off/on, but no display or fan spin. Main rails are present (5valw, 3valw, 1.8valw, vccst, 2.5v_ddr, etc ), even with the laptop turned on. LCD backlight circuit seems ok. The laptop previously had a dead pmic (pu500), which has been replaced and also added pu701 to compensate for the part difference. I'm maybe leaning towards a corrupt bios but I'm not to sure. I'll also add that the fan spins for a seconds then stops. Why could that...
                                09-19-2020, 06:04 AM
