XPS13 all rails present, continuous shutoff cycle
  • survivalbloke
    • Aug 2021
    • 280
    This machine was brought in because they did a battery replacement and shorted something out - They mentioned they saw a spark. Now what's happening is that I connect the power adapter and I've got 3.3, 5 and 20 rails all present, then, about every 8 seconds or so, the voltages all drop to zero for 1 second or less, then all go back to their normal voltages. So, it seems it's getting a random power-on signal as if the power button is being pressed, but it isn't. Can we safely say PCH is fried? No visible damage anywhere on the board. Drawing 117ma.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: XPS13 all rails present, continuous shutoff cycle
    What do you mean by saying "All rails are present"? Going by your statement u have ram supply as vcore which is impossible at consumption of 117mA.
    Nothing is wrong in the basic circuit of S5 stage as you are getting +19/3/5V rails. Check whether any voltage appears on ram coil during the brief interval when its turned on. It seems you have some damaged rail in S3 or S0 stage.
    Measure resistance across ram coil/vcore coil/vccsa coil with no power connected.
    • survivalbloke
      • Aug 2021
      • 280
      lol, I instantly feel like a noob.
      I will do my best to locate those components and test them as you suggest. I'll report back with my findings. Thanks so much!
      • survivalbloke
        • Aug 2021
        • 280
        Can you explain this to me?
        • survivalbloke
          • Aug 2021
          • 280
          resistances:
          ram coil = .3ohm
          +VCC coil = .4ohm
          +VCCSA coil = .3ohm
          On poweron signal, I am getting a brief flash of .245 vdc on the ram coil, PL601 in the boardview.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            U stated all rails are present. So that meand you do have ram supply+VCC core also available and thats impossible with consumption of 117mA.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Ram coil resistance at 0.3 OHMS is too low. Are you sure about your measurement?? If yes, then proceed to de solder the coil and then measure resistance on both the pads of ram coil.
              • survivalbloke
                • Aug 2021
                • 280
                Removed the ram coil. resistance of the coil is .3ohms and resistance between the pads is OL.
                • reformatt
                  • Feb 2020
                  • 1400
                  Resistance to ground is the required measurement. RAM rail usually measures about 100 ohms or more with RAM in, higher with RAM out.
                  A fried PCH usually results in a dead short across either 3.3V or 1.05V power rails.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    I didnt asked for resistance between the pads. Measure resistance on the two pads of coil(after coil is removed). Black meter probe to ground and red probe on these pads,one at a time. Btw, @reformatt has already expressed his doubts and very likely that will come true. Still measure the resistance to be absolutely sure.
                    • survivalbloke
                      • Aug 2021
                      • 280
                      Yes, thank you for clearing that up and it does appear true. I have 562ohms on one pad and OL on the other. Also, this board has soldered RAM.
                      Just so that I'm totally clear on this, I linked the schematic of this board above, and I am looking at PL601 which according to the schematic is labeled as part of the DDR controller circuit.
                      • survivalbloke
                        • Aug 2021
                        • 280
                        Thank you, I was confused. I'm nowhere near as experienced as many on this forum. I'm pretty good at sniffing out shorts on the 19+ rail but stuff like this, to me, is much more difficult. Really trying to learn though and really appreciate the help of folks here - means a lot.
                        • Sephir0th
                          • Oct 2020
                          • 1262
                          How can you now have 562 Ohms and O.L., when it was .3 before?
                          Did you measure resistance across the coil pads before?
                          FairRepair on YouTube
                          • reformatt
                            • Feb 2020
                            • 1400
                            The most important tools we have are our eyes. First thing is to do a physical examination of the board under a microscope. Most faults are corrosion based, but in this case you said a spark was seen so likely you are looking for a burnt component.
                            If the power is cycling this is usually either an overload, or the abscence of a required power rail. So if the physical inspection reveals nothing, you first measure all coils resistance to ground to check for shorts. CPU power rails all measure very low, so 2 ohms is not considered a short in that instance. If all good, you then go through your power rail sequence on pg 5 of the schematic, and power good signals for each rail.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              I'm also puzzled by this measurements. please clarify
                              • survivalbloke
                                • Aug 2021
                                • 280
                                OK, let me clarify, because originally I was measuring incorrectly because I misunderstood.
                                I'm hoping one of you have looked at that schematic and verified I'm looking at the right coil, but in the schematic it's labeled on the page marked "ddr controller" so I'm assuming it is, PL601.
                                Originally the coil was on the board and I measured .3ohms on either side of it. Then I was asked to remove the coil and measure resistance of the pads, but I misunderstood and measured from pad to pad, which was OL. After I was corrected, I measured each pad separately to ground, which showed one pad to ground at 562ohms and OL on other pad to ground.
                                video clip
                                • survivalbloke
                                  • Aug 2021
                                  • 280
                                  Thank you for the brief lesson! I have already completed a visual inspection under my scope. I guess I'm wrestling through the next phase of that.
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Going by the video, resistance on PL601 is fine and you can solder the coil back. It seems you measured incoorectly resistance on the coil earler.
                                    • survivalbloke
                                      • Aug 2021
                                      • 280
                                      Much appreciated, thank you. What would your next step be?
                                      • Sephir0th
                                        • Oct 2020
                                        • 1262
                                        Since we still know to less about where it is Stuck, i'd continue with a overview which power rails are where present in the Brief moment. This means to measure voltage of each coil and share the values, maybe written in a picture of the actual board.
                                        • skwarszczow
                                          Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                                          by skwarszczow
                                          This is my first post on the forum
                                          I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                                          Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                                          Before completing the purchase, we decided to erase...
                                          03-23-2025, 06:04 PM
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
                                        • iMuhtaseb
                                          A1502 2015 820-4924 no power
                                          by iMuhtaseb
                                          board came in cleaned up from a previous technician.. after examining the board visually I've seen some work done on the EFI/firmware..
                                          I've taken the chip out and it reads ok on Mac EFI Toolkit, I can read the SN and other information normally..
                                          I have taken a look into the board and I could not find anything suspecting.. I tried to look for corroded chips or corroded caps even to see if there's any areas damaged by liquid and I could not..
                                          I've taken some measurements:
                                          PPBUS 12.6
                                          PP5V_S5 present
                                          PP3v3_S5 present
                                          S4 rails when...
                                          06-29-2024, 05:29 AM
                                        • flusher
                                          Apple MBP16" A2141 820-01700 PMIC power cycles no boot no shorts
                                          by flusher
                                          Bought myself a project thing. Apple MBP16" A2141 820-01700
                                          No shorts, no visible waterdamage.
                                          Dead. no history.
                                          All USBC ports do 20V and charging battery.
                                          If you plug battery/charger PPBUS is 12.6v and all power rails like RTC, 3v3, 5v etc are present. U7800 PMIC all voltages are present APART from PPVCCPRIMCORE_PRIM_REG (not sure if it has to be present at this stage?! resistance is 40 Ohm). SSD 2.5, 0.9, 1.8 are present on both wings. Charger meter shows 30ma or something like this on charged battery.
                                          But what PMIC does is that it power cycles(dropping to...
                                          02-21-2025, 03:12 PM
                                        • luna69
                                          ideapad 320 14ikb - no power, all rails present
                                          by luna69
                                          Good day! I'm trying to troubleshoot an nm-b242 board. The laptop powers on by default when ac is plugged in. The power button responds and I can turn the laptop off/on, but no display or fan spin. Main rails are present (5valw, 3valw, 1.8valw, vccst, 2.5v_ddr, etc ), even with the laptop turned on. LCD backlight circuit seems ok. The laptop previously had a dead pmic (pu500), which has been replaced and also added pu701 to compensate for the part difference. I'm maybe leaning towards a corrupt bios but I'm not to sure. I'll also add that the fan spins for a seconds then stops. Why could that...
                                          09-19-2020, 06:04 AM
