A1990 ppbus_g3h shorted QA340 (Did i mess up?)
  • EsIstSimon
    • Feb 2022
    Hey there, i got a little question for you guys =)
    i bought a broken A1990 with a shorted ppbus_g3h (5V, 0.045ma, 0.5ohms on ppbus_g3h).
    I found that QA340 (gpu phase 3) was the issue and validated it by lifting LA340.
    The short was gone.
    I wanted to see, if the A1990 would draw 20V again, so i plugged the USB-C in and yes: 20V indeed.
    I wanted to see how the Macbook would behave in this state, so i put the motherboard back inside the case and attached everything.
    Plugged in the USB-C again and... i was back to 5V, 0.045ma. ppbus_g3h shorted again with now 10ohms.
    For now i only checked ppbus_g3h to ground and ppbus_g3h to the inductors of the cpu / gpu. LA650 now has the the same reading(10 ohms), so it seems like QA650 has blown!?
    I am not very experienced, but i was sure that i would not blow anything with attaching power to the machine in this state.
    So i was hoping anyone could give me advice on this.
    Was this expected behavior or just coincidence?
    Thanks in advance :-*
  • reessi
    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
    by reessi
    Hello:
    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
    I started on the ACER:
    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
    10-29-2024, 11:31 AM
  • wnt2fx
    A1989 (820-00850) - 5V@0.23A - shorted usbc cable
    by wnt2fx
    dear fellow tech enthusiasts, I would appreciate your help ! I have an 820-00850 here that died on a squeezed/shorted charging cable.
    I found several shorted ldo's on both U3100 and U3200. I replaced them with cd3215c00 ( originally c00Z )
    D3301 was shorted, removed without replacement for now. No other visual / obvious findings. ports look good.
    4,86V / 0,23A on usbc meter and ppbus 12.28V, ppdcin_g3h 5V and pp3v3_g3h 3.3V - all ports/orientation. Nothing obvious on a thermal picture, only t2 warms up to 35Celsius.
    1V1 LDO missing on u31/32...
    09-20-2022, 02:02 AM
  • alxtoulouse
    My experience with MacBookPro A1990 shorted
    by alxtoulouse
    just want to share my experience with my macbook pro 15" that I bought in dec 2019.
    For a few months, the screen was not working (just black) without any reason (no spill, no stepped on it, nothing except covid ), it was working fine on an external display.
    I started to browse the web and found some «*flexgate*» posts so I tried this way: I started to cut the wrong flex, and as I had the naked board in front of me, I decided to check some caps (I am a beginner in electronics and micro soldering)
    I got continuity on all the caps of the LCD...
    02-01-2023, 07:04 PM
  • Yanleb
    Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
    by Yanleb
    Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
    I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
    D608, good
    D618 RF101L4S, good (See warning 1 below)
    D619 RF101L4S, good (See warning 1 below)
    D865 RF101L4S, shorted (See warning 1 below)
    IC464 Inverter HA MC74HC1G14, shorted...
    03-09-2020, 12:00 AM
  • modtool
    HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
    by modtool
    Hi to all,
    the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
    I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
    I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
    04-01-2025, 08:22 AM
