LG gram - Not Charging
  • Ado02
    • Jul 2021
    • 100
    • United Kingdom
    I am working on an LG gram with a charging issue. The battery was replaced, but the problem didn't go away.
    Charging IC: ISL95520
    ACIN (Pin 1): 3.2v
    ACOK (Pin 2): 3.2v
    DCIN (Pin 18): 19v
    VDD (Pin 19): 5v
    CMRSC (Pin 29): 19v
    Charger plugged in: MOSFETs short to ground / and caps in region of r439
    I look forward to your help
  • mon2
    • Dec 2019
    • 14666
    Re: LG gram - Not Charging
    Never measure resistance to ground with power to the board. Power to the people is ok.
    Confirm it.
    • Ado02
      • Jul 2021
      • 100
      • United Kingdom
      Originally posted by mon2
      Never measure resistance to the ground with power to the board. Power to the people is ok.
      Confirm it.
      I didn't know that. I am still learning.
      I can't find a short when the charger is not plugged in.
      • mon2
        • Dec 2019
        • 14666
        Does the unit power up ok with the adapter ?
        Fault is that the battery is not charging?
        Does the graphic show that the battery is charging ?
        • Ado02
          • Jul 2021
          • 100
          • United Kingdom
          The fault is that the battery is not charging.
          The laptop powers on with the charger. The laptop will stay on when the charger is plugged out. However, it will not power on with just the battery. This is a new battery with 48% charge - but when the charger is plugged out, Windows prompts "low battery". When the charger is plugged in - under the battery icon, I just get 'plugged in'.
          • mon2
            • Dec 2019
            • 14666
            Link or post the schematic if available.
            When the charger is plugged in, does the battery icon show the charging graphic?
            Is the battery a known good battery?
            So battery is @ 48% and discharging since it fails to charge?
            Measure, with care, the voltage to ground on each pin of the battery connector with the battery charger attached.
            • Ado02
              • Jul 2021
              • 100
              • United Kingdom
              Battery: Is brand new and measures 7v
              Charger plugged in - shows charging graphics - stops and message says plugged in.
              Battery connector:
              3 + Pins: 0.6v
              Signal Pins: 3.3v
              7v goes to first MOSFET (see attached image) (one above C310 marking)
              2nd mosfet 0.6v on both ends, including gate.
              C333, C327 and C334 - 7v
              • mon2
                • Dec 2019
                • 14666
                Post the full topside markings of the mosfet so we can review the datasheet.
                • Ado02
                  • Jul 2021
                  • 100
                  • United Kingdom
                  As requested. Thank you.
                  • mon2
                    • Dec 2019
                    • 14666
                    See attached for the datasheets for each mosfet.
                    1) AON7400 is a N-channel mosfet. So pin # 4 (Gate) must be HIGHER than the voltage being passed between source & drain pins.
                    2) AON7405 is a P-channel mosfet. So pin # 4 (Gate) must be LOWER than the voltage being passed between source & drain pins.
                    3) Can you measure the voltage on each pin (group) again and post the readings?
                    source (1-2-3) ; pick any
                    gate (4)
                    drain (5-6-7-8) ; pick any
                    • Ado02
                      • Jul 2021
                      • 100
                      • United Kingdom
                      gate (4)
                      7400A
                      Pins 1-2-3 / 0.2v
                      Pin 4 / 0v
                      Pin 5-6-7-8 / 7.18v
                      7405
                      Pins 1-2-3 / 0.66v
                      Pin 4 / 0.63v
                      Pins 5-6-7-8 / 0.2v
                      • mon2
                        • Dec 2019
                        • 14666
                        So with Pin 4 = 0v, 7400A mosfet cannot turn ON.
                        Can you post or link the schematic for this logic board?
                        If not available, you will have to trace where the GATE pin travels on the board and this will likely be a (black body) resistor. The resistor will then be driven by the charger IC.
                        The charger IC will offer the boosted voltage to enable this mosfet.
                        • Ado02
                          • Jul 2021
                          • 100
                          • United Kingdom
                          I traced the pin 4 (gate) to pin 25 BGATE (0v charger / no battery).
                          With the battery plugged in I get 11v on the pin 4 (gate) and 7v across the 2nd Mosfet.
                          Will the power pass to the battery connector if the battery is not connected?
                          Also, do you have any other suggestions?
                          • mon2
                            • Dec 2019
                            • 14666
                            Then BGATE has a valid voltage to enable to the battery mosfet. If the battery is not detected, the charger IC will not enable this mosfet.
                            This battery mosfet is like a solid state (no moving parts) on/off switch for the battery voltage - to power the logic board.
                            This mosfet should be enabled to power the logic board when the power adapter is not connected to the logic board.
                            Attach the charger and still keep the battery on the logic board.
                            Measure again the gate voltage to ground on this mosfet. Post the measurement.
                            • Ado02
                              • Jul 2021
                              • 100
                              • United Kingdom
                              7400A Pin 4 / 12.9v
                              7405 Pin 4 / 2.26v
                              I also found 2 more Mosfets on the other side of the connector. Please see the image
                              Q23
                              Charger / no battery
                              Pins 1-2-3 7.16v
                              Pin 4 7.16v
                              Pin 5-6-7 19.11v
                              Battery No Charger
                              Pins 1-2-3 7.62v
                              Pin 4 7.62v
                              Pin 5-6-7 7.11v
                              Battery + Charger
                              Pins 1-2-3 7.22v
                              Pin 4 8.22v
                              Pin 5-6-7 18.98v
                              Q25
                              Pins 1-2-3 0v
                              Pin 4 0v
                              Pin 5-6-7 7.18v
                              Battery No Charger
                              Pins 1-2-3 0v
                              Pin 4 0v
                              Pin 5-6-7 7.62v
                              Battery + Charger
                              Pins 1-2-3 0v
                              Pin 4 0v
                              Pin 5-6-7 7.47v
                              • mon2
                                • Dec 2019
                                • 14666
                                Test to see if these new mosfets are leaking.
                                Remove all power.
                                Meter in resistance mode.
                                Measure the resistance across the mosfet pins.
                                Source (1-2-3) & Drain (5-6-7-8)
                                Source (1-2-3) & gate (4)
                                gate (4) & drain (5-6-7-8)
                                Post each measurement.
                                • Ado02
                                  • Jul 2021
                                  • 100
                                  • United Kingdom
                                  Remove all power.
                                  I am not sure if negative and positive probs need to be in some order.
                                  The multimeter was set to continuity with the diode mode.
                                  Q23
                                  Pins 1-2-3 (N) - 4 (P) / 490
                                  Pins 1-2-3 (P) - 4 (N) / 0 Beep
                                  Pins 1-2-3 (N) - 5-6-7 (P) / 500
                                  Pins 1-2-3 (P) - 5-6-7 (N) / 1 (No change on the meter)
                                  Pins 4 (N) - 5-6-7 (P) / 1294
                                  Pins 4 (P) - 5-6-7 (N) / 1 (No change on the meter)
                                  Q25
                                  Pins 1-2-3 (N) - 4 (P) / 440
                                  Pins 1-2-3 (P) - 4 (N) / 996
                                  Pins 1-2-3 (N) - 5-6-7 (P) / 420
                                  Pins 4 (N) - 5-6-7 (P) / 1200
                                  • mon2
                                    • Dec 2019
                                    • 14666
                                    • Ado02
                                      • Jul 2021
                                      • 100
                                      • United Kingdom
                                      Sorry to be a pain but which is the best one?
                                      • mon2
                                        • Dec 2019
                                        • 14666
                                        Start with the 200k scale. If you do not get a reading, go higher.
                                        If the resistance is too low, the mosfet is defective.
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                          LG Gram Gram 17 Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Gram 17 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gram 17 boardview and Gram 17 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LG Gram Gram 17...
                                          09-07-2024, 06:11 AM
                                          LG Gram LG gram 16Z90P-K.AA85A1 16GB_512GB - Black Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram LG gram 16Z90P-K.AA85A1 16GB_512GB - Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LG gram 16Z90P-K.AA85A1 16GB_512GB - Black boardview and LG gram 16Z90P-K.AA85A1 16GB_512GB - Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-07-2024, 03:40 AM
                                        • Thomasraud
                                          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                          by Thomasraud
                                          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                          QUOTED
                                          -It works on charger (without battery connected-only charger)
                                          -It works on battery (without charger connected-only battery)
                                          -& it also works when plugged in battery & charger, but it's not charging the battery
                                          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                          and..
                                          QUOTE
                                          The IC cannot maintain the input current level
                                          06-28-2022, 06:47 PM
                                        • Scoff
                                          HP Probook 470 G4 - Power and Charging Problem
                                          by Scoff
                                          Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                          Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                          07-03-2023, 09:28 AM
