4540 (Rocky_Intel_MB, 11243-1 (48.4SI01.011)) No LVDS
  • r ez a
    • Sep 2014
    • 39
    • iran
    hello friends
    this board came with dead kbc, i replace it and its alive now
    hdmi display is good but there is no lvds
    i tried new bios,led and led cable
    LCDVDD_EN=v0 and 36Ω
    if i jump pin 3 and 4 of u4901 led will turn on just black
    i see activity on edid
    any idea?
    should i try new kbc?
  • mon2
    • 14659
    Re: 4540 (Rocky_Intel_MB, 11243-1 (48.4SI01.011)) No LVDS
    Link or post a schematic.
    • r ez a
      • Sep 2014
      • 39
      • iran
      here it is
      • mon2
        • 14659
        Resistance to ground of LCDVDD_EN is 36 ohms?
        That is very low.
        Measure the voltage to ground of
        LCD_SMBCLK_C
        LCD_SMBDATA_C
        Pin 11 of Lvds connector
        Pin 25 of Lvds connector
        Pin 26 of Lvds connector
        If the resistance to ground is very low on lcdvdd_en then consider to remove u4901 and measure again. No power when measuring in resistance or diode mode.
        • r ez a
          • Sep 2014
          • 39
          • iran
          That is very low.
          LCD_SMBCLK_C
          LCD_SMBDATA_C
          i measure resistance when it was plugged
          when its totally off its 100k ohm
          DISP_OFF#= 0V
          LCD_SMBCLK_C =3.3V
          LCD_SMBDATA_C=3.3V
          • mon2
            • 14659
            DISP_OFF#= 0V
            The logic board is requesting the lcd display to remain OFF.
            Check if the status changes with the top lid or angle of the opening.
            There should be a lid sensor on board as well.
            Toggle the hotkey used for int or ext display to see if this voltage changes.
            • r ez a
              • Sep 2014
              • 39
              • iran
              i have another same motherboard and it work normally in same situation
              currently LID_SW# =1V
              after i remove D4901 :
              LID_SW#= 3.3v
              DISP_OFF#=0V
              LCDVDD_EN=0V
              LCD_BL_EN=0V
              im facing wierd problem here
              schematic and pcb are different
              DISP_OFF# goes to pin 21 not 11
              and CAM_USB_10+ that must be on pin 21 is on pin 11:|
              LVDS Socket is 40 pin but pin 30 to 40 are not ground same as schematic, it's numbering doesn't make sense
              • r ez a
                • Sep 2014
                • 39
                • iran
                i put all parts back and its working now:|
                • NolesFan
                  Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                  by NolesFan
                  Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                  10-24-2024, 06:36 PM
                • lpraderi
                  Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
                  by lpraderi
                  Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
                  In some cases to use LVDS screen PCB use converter IC RTD2132/6
                  Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
                  at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
                  Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
                  11-25-2023, 09:31 AM
                • TCCTech
                  HP Elitebook LVDS port
                  by TCCTech
                  Hi all, I appreciate any help at all on this I have an HP Elitebook 840 a customer spilled tea on it and it shorted/melted the LVDS port I found the schematic here
                  file:///E:/Users/BBB/Downloads/HP%20EliteBook%20840%20-%20ZBOOK%2014%206050A2559101-MB-AX1%20COMET%20DIS%20SI2%20Schematics.pdf
                  But i can not find the part number for the LVDS port if anyone knows where I can get a LVDS port I would appreciate it. Every time I google it I get lots of LVDS cables but not the port/connector.
                  Thank you in advanced...
                  09-02-2022, 05:18 PM
                • Scincidae
                  UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
                  by Scincidae
                  I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
                  I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
                  04-24-2022, 06:00 PM
                • ResoluteHawk
                  Connecting an LVDS/eDP cable into a live motherboard
                  by ResoluteHawk
                  Could anyone explain the reasoning behind why connecting an LVDS or eDP cable into a laptop motherboard, with the battery still connected, kills the CPU/PCH/SuperIO/GPU?
                  Today I had a customer with a Lenovo Legion 5 that I diagnosed as a dead iGPU inside their Ryzen 5900HX. They told me that they connected their screen to the motherboard without first disconnecting the battery.
                  I want to understand the nitty gritty behind why it kills components if power is not disconnected first.
                  08-04-2025, 04:39 PM
