A2338 820-02020-a
  • Strolch
    • Nov 2017
    • 245
    • Deutschland
    A2338 820-02020-a
    I have a MacBook Pro A2338 with liquid damage. And some parts are broken. including The 2 pcs CF120 and CF 121 USBC_ATC1_R2D_C_P<1>. I have different LogicBoards from which I can take parts. But I can't find you. Can someone tell me exactly what SMD parts are? thanks
  • Strolch
    • Nov 2017
    • 245
    • Deutschland
    Re: A2338 820-02020-a
    Hello, can anyone tell me what the parts are or where I can get them? thanks
    • mon2
      • Dec 2019
      • 14669
      Hi. See attached. Is the same as your board layout ?
      • Strolch
        • Nov 2017
        • 245
        • Deutschland
        yes 100%
        • mon2
          • Dec 2019
          • 14669
          See attached. These are very common DC blocking caps - nothing special; any brand will do.
          Value:
          0.22uF X5R or X7R
          0201 size (tiny !!!)
          6v3 or higher is fine
          Suggestion: Pickup 100 of these on cut tape as they are very cheap & easy to lose!!
          Where do you shop for such parts? RS / Digikey / Mouser ?
          • Strolch
            • Nov 2017
            • 245
            • Deutschland
            I buy from Ali, do you have a link where I can get the parts
            • Strolch
              • Nov 2017
              • 245
              • Deutschland
              Oh I didn't see pin 2 on the schematic. It was late after work ;-))
              • mon2
                • Dec 2019
                • 14669
                Arrow / RS / DK / Mouser may be faster and better but Aliexpress does offer the parts.
                https://www.aliexpress.com/item/1005...d=LZjyx8Oadkwf
                • Strolch
                  • Nov 2017
                  • 245
                  • Deutschland
                  I can't open the link in Germany. Worse than in China here in Germany!
                  • mon2
                    • Dec 2019
                    • 14669
                    Search for '0.22uf 0201' on Aliexpress and it is the first match.
                    • Strolch
                      • Nov 2017
                      • 245
                      • Deutschland
                      I can not open the Shop. that is Germany. Not normal! I buy it now from Digital Key
                      Web-Kennung: 336011520
                      Artikel im Warenkorb: 1
                      Zwischensumme: 0,84 €
                      Versand: 18,00 €
                      MwSt.: 3,58 €
                      Gesamt: 22,42 €
                      • Mark D
                        Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                        by Mark D
                        The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                        10-29-2024, 03:15 PM
                      • todordm
                        Macbook A2338 / A2337 - Replace SSD
                        by todordm
                        There are a lot of Video Tutorials how the SSD of A2338 or A2337 can be upgraded. Normally they say you can order the bigger SSD chips (0 and 1) from China. But as far as I understand you can take the SSD chips of one A2337/A2338 and install on another, put to DFU mode, do the recovery, reinstall etc... I tried that several times (tried to upgrade 256GB to 512Gb, then to 1TB, then to another 256Gb)... nothing worked. So my question to the community is: can I just take the SSD chips from one A2338 and intall them on another A2338 (taking care of course of the 0 and 1 positions)? Or I have always...
                        01-17-2024, 03:55 AM
                      • 2elw
                        SVOD4 PCB pictures + parts
                        by 2elw
                        Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                        STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                        GW1N-UV9UG169C6/I5 FPGA - Its a...
                        07-04-2025, 12:23 PM
                      • User555111
                        A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                        by User555111
                        Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                        02-05-2024, 08:16 AM
                      • SurrealMustard
                        What parts can be salvaged from a plasma with a damaged display panel?
                        by SurrealMustard
                        I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                        03-09-2025, 08:29 PM
