[SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
  • slimmy182
    • Apr 2021
    • 105
    • italy
    Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
    I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
    Looking on google I found this:
    "Differential Diagnosis for a clicking sound from system board with low voltage as measured by a USB-C amp meter.
    • Corroded or failed PP3v8_AON creation MOSFET. (Q5800, Q5820, Q5840.)
    • Corroded or failed PP3v8_AON buck converter IC. (U5700)
    ➤ Diagnostic Steps
    1. Measure voltage on PP3v8_AON. (Normal voltage = 3.8v. ) You will likely find that the voltage is low and pulsing slightly or completely absent. This confirms the diagnosis.
    2. Perform a visual inspection of the system board. This failure is very uncommon without liquid damage. Often times, you will find that one of the 3v8_AON MOSFETs will be corroded, or that U5700 itself will be corroded. If the MOSFETs (Q5800, Q5820 or Q5840) are corroded, proceed to the Repair Steps below for "PP3v8_AON creation MOSFETs corroded" below. If the PP3v8_AON buck converter IC (U5700) is corroded, proceed to the "PP3v8_AON buck converter IC corroded" repair steps below.
    ➤ Repair Steps
    - Replace Q5800, Q5820 and Q5840 together. It's important to replace all 3 MOSFETs at the same time as if one MOSFET failed, it may have damaged the others. Replacement of U5700 is not necessary as long as it isn't corroded and as long as the clicking sound does not persist after replacement of the MOSFETs.
    - Replace U5700. Replacement of the PP3v8_AON creation MOSFETs is not required unless they are corroded or if the clicking sound persists after replacement of U5700.
    Verify correct voltage on PP3v8_AON after the relevant repair is performed."
    reference: repair.wiki/w/A2338_2020_13%22_MacBook_Pro
    I found no visible problem on Q5800, Q5820, Q5840 mosfets, neither U5700 IC.
    Then I measured voltage of P3V8_AON_VSW1 on L5800, and I got 0V.
    PPBUS_VMAIN_VIN_ISNS measured on C5800 pin 1 is 7.9V
    C5701
    1 P3V8AON_PVCC measure 4.33V
    2 GND
    C5702
    1 PP5V_AON measure 4.54V
    2 GND
    I will be really thankfull to anyone who would help me to sort out this problem and get back to life this Mac. I know I'm a real noob diagnosing problems, please be patient. Any advice is really welcome.
  • mon2
    • Dec 2019
    • 14211
    Re: M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
    Any power rail that you deem to be a lower than expected voltage, check its resistance to ground.
    Remove all power -> meter in resistance mode -> measure its resistance to ground to confirm if the load is 'normal' or perhaps a short. A low resistance could be due to a shorted cap downstream on this rail.
    • slimmy182
      • Apr 2021
      • 105
      • italy
      Resistance to ground measures:
      CY12B
      1 PP3V8_AON 800000 Ohms ( 008 in 2000k scale, is that right?)
      then i cheked 3 big coils:
      L5800
      1 P3V8AON_VSW1 800000 Ohms ( 008 in 2000k scale )
      2 PP3V8AON_PH1 800000 Ohms ( 008 in 2000k scale )
      L5820
      1 P3V8AON_SW2 OL
      2 PP3V8AON_PH2 800000 Ohms ( 008 in 2000k scale )
      L5840
      1 P3V8AON_SW3 800000 Ohms ( 008 in 2000k scale )
      2 PP3V8AON_PH3 800000 Ohms ( 008 in 2000k scale )
      THEN
      L5800
      1 P3V8AON_VSW1 399000 Ohms (39.9 in 200k scale)
      2 PP3V8AON_PH1
      C5701
      1 P3V8AON_PVCC 327000 Ohms (32.7 in 200k scale)
      2 GND
      C5702
      1 PP5V_AON 47700000 (477 in 2000k scale)
      2 GND
      No short seems to be present. Thats right? Thank tou so much Mon2.
      PS I re-uploaded the pics in high quality.
      I cannot tell for sure, but Q5800 does it seem a little "shadowish" ?
      • slimmy182
        • Apr 2021
        • 105
        • italy
        Is there anything else I can check?
        • mon2
          • Dec 2019
          • 14211
          1) resistance checks look ok.
          2) meter in voltage mode (20v or higher is ok).
          What is the voltage to ground of PPBUS_AON ? (measure @ F5200)
          3) the logic board is stuck @ 5 volts? It should be @ 20 volts if all is well with the CD3217 ACE controller ICs.
          That is, BOTH CD3217 controllers must be working for the 20 volt power delivery contract to be negotiated out of the PD power adapter. Be sure that you are using a known good and suitable power adapter for this unit.
          Attach the power adapter and measure (with care) the voltage of each LDO rail that is present on each of the CD3217 devices.
          • slimmy182
            • Apr 2021
            • 105
            • italy
            F5200
            1 PPVBAT_AON_CHGR_REG 7.88V
            2 PPBUS_AON 7.88V
            CF408
            1 PP3V3_UPC0_LDO 0V , diode mode to ground reading = 594.
            2 GND
            CF405
            1 PP1V5_UPC0_LDO_CORE 0V , diode mode to ground reading = 626.
            2 GND
            CF508
            1 PP3V3_UPC1_LDO 3.43V , diode mode to ground reading = 602.
            2 GND
            CF505
            1 PP1V5_UPC1_LDO_CORE 1.57V , diode mode to ground reading = 622.
            2 GND
            I'm using a known good and suitable power adapter for sure!
            I must say that majority of the time when i connect DCIN multimeter display 5V and 0.42A but sometimes, after disconnecting a re-connecting again, display 5V and 0A (then 0.071A and again 0A)
            • slimmy182
              • Apr 2021
              • 105
              • italy
              Ok, that's weird.
              I took another time measure when the multimater display 5V 0A, and that is:
              F5200
              1 PPVBAT_AON_CHGR_REG 12.30V
              2 PPBUS_AON 12.30V
              here, goes to 12.30 then 0V then again 12.30V and stay stable after few second.
              CF408
              1 PP3V3_UPC0_LDO 3.43V ,
              2 GND
              CF405
              1 PP1V5_UPC0_LDO_CORE 1.57V ,
              2 GND
              CF508
              1 PP3V3_UPC1_LDO 0V ,
              2 GND
              CF505
              1 PP1V5_UPC1_LDO_CORE 0V ,
              2 GND
              They are inverted! What is happening here?
              L5800
              1 P3V8AON_VSW1 0.18V
              2 PP3V8AON_PH1 0.18V both not stable, goes up and down to 0V to 0.18V
              L5820
              1 P3V8AON_SW2 0.18V
              2 PP3V8AON_PH2 0.18V
              L5840
              1 P3V8AON_SW3 0.18V
              2 PP3V8AON_PH3 0.18V
              • mon2
                • Dec 2019
                • 14211
                The ACE controller that is active should offer the voltage rails.
                In your last batch of measurements - you moved the power adapter to another connector? Then UF400 ACE controller was used ?
                • slimmy182
                  • Apr 2021
                  • 105
                  • italy
                  Nope. Just reconnected.
                  It does act the same on both ports, sometimes 5V 0.42A, sometimes 5V 0A
                  Anyway I keep hearing that popping/cralkig sound but I cant really identify where it does come from, but I guess the area is L5820, id does make this sound only when it takes 5V 0.42A
                  • slimmy182
                    • Apr 2021
                    • 105
                    • italy
                    Ok, I realize that when the board is cold and connect to DCIN multimeter display 5v 0.4A and consuming 2W, the second time I connect show 5V 0A (both usb-c port). I was able to locate what is becoming hot using my lips (not so hot) when it takes 2W, and it is U5700 renesas chip.
                    • slimmy182
                      • Apr 2021
                      • 105
                      • italy
                      Can worth replace Renases?
                      • dellxps15
                        • Feb 2014
                        • 1588
                        • italy
                        12.3 volt on ppbus looks like bad t2 communication.
                        • slimmy182
                          • Apr 2021
                          • 105
                          • italy
                          Thanks. As far I know, M1 does not have T2, o mi sbaglio?
                          • slimmy182
                            • Apr 2021
                            • 105
                            • italy
                            Here it is thermal image
                            • slimmy182
                              • Apr 2021
                              • 105
                              • italy
                              This could be marked as solved.
                              Upon replacing U5700 renesas chip from a donor board Macbook is fixed, perfectly working.
                              • B0r1s
                                Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                by B0r1s
                                PSU - BN44-00878A
                                Symptoms:
                                The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                A weak clicking sound was coming from the transformer.
                                Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                Progress:
                                After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                01-17-2023, 04:58 PM
                              • beetle1303
                                Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                by beetle1303
                                I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                01-13-2025, 08:49 PM
                              • mikelu53
                                Samsung UN60D8000YF Clicking BN44-0432A
                                by mikelu53
                                I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
                                The set was working then not,then started clicking.
                                Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
                                Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
                                A schematic or suggestion would be great.
                                01-21-2023, 03:14 PM
                              • bffargo
                                2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                by bffargo
                                LG 60PB66550 NOV 2014
                                PSU: EAY63168603
                                PCB: EAX65359531 2013.11.01 Rev:1.0
                                Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                Symptom:
                                While watching, just went black and started clicking relay every few seconds.
                                Initial diagnosis:
                                Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                Deeper diagnosis:
                                Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                09-09-2022, 07:34 PM
                              • nbnb
                                Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
                                by nbnb
                                I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
                                Any idea what is causing the clicking sound? Any easy way to...
                                11-23-2019, 12:03 PM
