Msi Gp76 20V short Rail
  • brain123
    • Feb 2017
    • 10
    • deutschland
    I have a Msi Gp76 mainborad here that cannot be switched on."20V rail has a short circuit. One of the mosfets from the graphics card burned out and was unsoldered. The board is still hot without the mosfet.
    What could be the problem?
  • mon2
    • Dec 2019
    • 14663
    Re: Msi Gp76 20V short Rail
    Remove all power. Meter in resistance mode. What is the resistance to ground?
    Post or link the schematic and boardview files.
    • brain123
      • Feb 2017
      • 10
      • deutschland
      Unfortunately I didn't find any schematic or view.
      • mon2
        • Dec 2019
        • 14663
        At 0R3 ohms to ground, this could be the GROUND pad on each device. Post the top side markings of the mosfets that were present on the logic board.
        • Victor Moreira Silva
          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
          by Victor Moreira Silva
          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
          Well, my decice specs are the following:
          Model: Acer Nitro 5 AN517-54-55T5
          CPU: Intel Core i5-11400H
          GPU: NVIDIA GeForce GTX 1650
          Motherboard: GH51G LA-L181P Rev:1c
          The symptom:
          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
          05-26-2025, 10:49 AM
        • grimacelord
          Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
          by grimacelord
          Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
          After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
          I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
          10-24-2024, 12:31 PM
        • nagkiller
          Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
          by nagkiller
          Hello everyone!
          This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
          After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
          Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
          The attached boardview file is very similar to this grafic card, which I am basing the repair on.
          I would like some...
          05-10-2025, 09:19 AM
        • joshAU
          Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
          by joshAU
          Hi all.
          This notebook was showing no signs of life.
          I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
          However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
          If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
          I tried replacing the MOSFET with a new one, but again no voltage on the...
          05-29-2024, 12:33 AM
        • techrepairheide
          Gaming laptop Clevo NH79EP with short on 5VS-rail
          by techrepairheide
          first of all I want to apologize for my bad English, but I try to give my best.
          Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
          For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
          10-13-2024, 02:49 PM
