I need how to open this Dell service menu option in dell latitude e6420
  • sohail5307
    • Jul 2015
    • 35
    • india
    I need to open service menu of Dell laptops like image in attachment
    Ignore my English
    I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem
  • tomodachi
    • Apr 2012
    • 606
    • Turkey
    Re: I need how to open this Dell service menu option in dell latitude e6420
    Same need here,how do we access to manufacturing mode ?
    • khaahk
      • Dec 2013
      • 806
      • Estonia
      Battery id is entered into boot block of the MEC and this is known only to Dell. Battery charging will be disabled in normal mode. For now only possibility is to use MEC from donor board. The boot block is protected from read, so you can not use working MEC to copy it.
      • sohail5307
        • Jul 2015
        • 35
        • india
        Now I think I found some new information
        I think need to gnd fwp# for unlock boot info of mec sio
        Checkout pdf from attachment
        • khaahk
          • Dec 2013
          • 806
          • Estonia
          If the internal register of MEC has BOOT_PROTECT_EN set then reads will be disabled. I think that fwp pin is an external way of protecting writes to MEC. Check MEC1632 datasheet for reference.
