A1466 820-00165 weird issue..
  • Instafixx
    • Jul 2022
    • 374
    • India
    Re: A1466 820-00165 weird issue..
    I have a similar issue with Macbook A1466. Someone had worked on the U6100. We went ahead and reflowed it properly. Now the macbook turns on. Will get Chime and Apple Logo, but the loading bar gets stuck at 80% first and then takes time and goes upto 100% and stays stuck.
    This happens only on an adapter - it wont turn on with a battery only.
    • mon2
      • Dec 2019
      • 14659
      Check the voltage to ground of each pin of the battery connector. Post all measurements.
      • SuperJames
        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
        by SuperJames
        This one's a weird one, and still unsolved despite it having gone back to Dell once.
        Specs
        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
        Backstory
        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
        10-23-2023, 04:09 PM
      • ugamazing
        820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
        by ugamazing
        So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
        1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
        2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
        04-10-2024, 08:06 AM
      • lukkihapsi
        Asus Vivobook X515JA Weird Boot Issue
        by lukkihapsi
        Asus Vivobook X515JA Laptop
        Issue :
        Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
        Tried :
        Cleaned inside for dust, applied fresh thermal paste. No Change!
        Removed keyboard, Trackpad, fingerprint sensor. No Change!
        Removed Internal SSD. No Change!
        Updated BIOS to latest version. No Change!
        Removed battery and pressing power button for 1 minute. No Change!
        Weird Part :
        Upon turning laptop ON, screen lights up - stays black,
        I...
        07-07-2025, 12:07 PM
      • tommygun26
        Hp 6510b weird issue
        by tommygun26
        Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
        02-26-2023, 06:00 AM
      • Spider1211
        Weird but interesting issue with DELL 3542 (intel mb 13269-1)
        by Spider1211
        Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
        Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
        Backstory:
        Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
        Power supply draw:
        Voltage: 19.40V
        Amp draw: 0.006 - 0.007A
        Amp draw...
        04-07-2021, 03:21 PM
