Macbook Pro 2016 A1707 820-00281-A not booting
  • PACh
    • Feb 2022
    • 24
    • Austria
    Hi, I got the macbook pro 2016 820-00281-A that doesnt boot, I checked almost all rails and they are present, didnt find any short and the amp sequence looks ok but doesnt boot. trackpad enabled, keyboard shift key light not present, when I insert a usb stick its light turns on for a sec. but then no activity. with display disconnected and connected to external monitor same problem. I reflashed the bios with a clean me bin that I downloaded from this forum no difference.
    L7211, L7221, L7231 on boot: 1.112 then 0.700 A
    PCH and other chips get hot but not really hot (please see pics)
    The videos are the amperage behaviour while booting, the first is with the battery attached, the second is without battery attached. When the battery is connected doesnt make one reboot cycle. I think the battery is already charged because before with the battery connected it was using like 1Amp more. Both videos are with the board connected (everything connected) I tried disconnecting one by one trackpad, keyboard, touchpad, etc and same problem.
    Battery attached
    https://imgur.com/a/SO7Fh0y
    No Battery attached
    https://imgur.com/a/0enoGKa
  • evolpe
    • Aug 2020
    • Italia
    Re: Macbook Pro 2016 A1707 820-00281-A not booting
    do you have some hotspot on cpu/gpu?
    • mon2
      • Dec 2019
      • 14659
      Could be bad GPU.
      See here:
      No image, EDP_PANEL_PWR_EN missing, machine taking 20 V and 1.4 A at the first kick then 20 V 0.9 A and the current was dropping down to 0.8 A -> 0.6 A -> 0.4 A
      https://repair.wiki/w/A1707_2016-201...ar_MacBook_Pro
      • Hauke
        MacBook Pro 15" A1707, 2016 - No Display and Touch Bar
        by Hauke
        Hi, I am asking for a little troubleshooting advice.
        The laptop seems to boot up fine. Caps lock is working, the touch pad has haptic feedback, and even the "charger plugged"-sound is present.
        Power consumption is about 15-30W at boot and idles at about 20W.
        Unfortunately, the display and the touch bar are completely black (No signal and no backlight).
        I don't get a signal on an external USB-C display either. Also not in safe mode.
        I noticed that only the left fan (from the bottom side, hinge on top) seems to spin up. I think...
        09-03-2025, 04:04 AM
      • CG_Dionysos
        MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
        by CG_Dionysos
        I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
        • Model: A1707
        • 15-inch, Mid 2017
        • 3.1 GHz Core i7
        • 16 GB RAM
        • Radeon Pro 560
        • 1 TB SSD
        • Board number: 820-00928-A
        I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
        Thanks in advance!
        Greetings from Germany...
        09-16-2025, 06:43 AM
      • leonemax81
        Macbook a1707 820-00281 Battery no Power
        by leonemax81
        Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
        08-23-2024, 09:24 AM
      • sofles
        Macbook a1707 2017 model 820-00928 GPU issue
        by sofles
        Hello there
        I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
        I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
        11-21-2024, 05:25 AM
      • jesi
        MacBook Pro 820-00281-A A1707 macbook
        by jesi
        hi all techs
        require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
        adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
        update:
        when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
        08-23-2025, 02:35 PM
