Macbook Air A2179 worked before but dead now
  • kino0924
    • Jan 2023
    • 12
    Hi,I purchased a broken macbook air which claims to be not working keyboard/trackpad.
    I was hoping to be able to fix it by replacing keyboard/trackpad but it got worse.
    1. Macbook came with Catalina
    2. Keyboard Backlight was working
    3. I tried to update to latest OS through software update and it was having error with updating (download was successful and it went reboot).
    4. Error was stuck on boot loop of where It tries update but complaining boot disk blabla
    5. So I connected to Apple Configurator 2 to see if I can revive.
    6. Magically, I can enter DFU with built in keyboard so not sure if its really keyboard issue now.
    7. I tried to revive device but I received 0x3FFF
    8. I also tried restore option but same result 0x3FFF
    9. I also checked the serial number, backplate and system information reported same serial (I got this when macbook was originally working)
    10. When I opened it, I noticed that someone worked on logic board (missing lots of screw)
    Apple Configurator 2 shows this error
    "The operation couldn't be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xFFFFFFFFFFFFFFFF (-1) [sys = 0x3F, sub = 0xFFF, code = 0x3FFF (16383)]]"
    I tried to pull more detailed log but I couldnt find it. (only older version of apple configurator was producing it i guess)
    So now, Im stuck. Where should I starts to tackle?
  • kino0924
    • Jan 2023
    • 12
    Re: Macbook Air A2179 worked before but dead now
    Also between step 4 and 5 (macos update and Apple configurator)
    I also tried online recovery (command + r or ctrl + command + r. not sure which one worked)
    I received -2100F error
    • kino0924
      • Jan 2023
      • 12
      Also, I tried checkra1n to see if I get anything. (between, i dont think its icloud locked)
      It detects DFU mode and also sends payload
      == Checkm8 Trying to run payload... ==
      If everything went correctly, you should now have code execution.
      DFU device disconnected
      After this, my macbook does not go back to download mode for further execution
      1. Faulty logic board somewhere
      2. Faulty T2 chip/flashrom
      3. Dead SSD
      What could it be...?
      • kino0924
        • Jan 2023
        • 12
        SERIAL: FVFCXXXXXXXX
        Unlocked: False
        Labor Covered: False
        Limited Warranty: False
        Onsite Coverage: False
        Part Covered: False
        Personalized: False
        Purchase Date: 2020-07-29T00:00:00Z
        Warranty Status Code: OO
        Warranty Status Description: Out of warranty (no coverage)
        Config Code: MNHP
        Config Description: MBA 13.3 SG/1.1GHZ DC/8GB/256GB-USA
        Cto Configuration: 8GB 3733 MHZ LPDDR4X MEMORY, 256GB SSD STORAGE, MAC OS,J230, PKG,BTR,THIN A,J230 (US/CH), NO PRO APPS BUNDLE PREINSTALLED, NO FINAL CUT PRO PREINSTALLED, MAC OS WW1,J230, NO NUMBERS PREINSTALLED, TWO THUNDERBOLT 3 PORTS, MACBOOK AIR 13-INCH SPACE GRAY, 1.1GHZ DUAL-CORE INTEL CORE I3, FORCE TOUCH TRACKPAD, INTEL IRIS PLUS GRAPHICS, KEYBOARD,A,J230, RETINA DISPLAY WITH TRUE TONE, 1.1GHZ 2C/8GB/256GB/WIFI,J230, NO LOGIC PRO PREINSTALLED, NO APERTURE PREINSTALLED, NO KEYNOTE PREINSTALLED, PROC ENCLOSURE 1,J230, TOUCH ID, COUNTRY KIT,A,J230
        Loaner: False
        Product Description: MacBook Air (Retina, 13-inch, 2020)
        Product Line: 508935
        Sold To Name: BEST BUY CANADA LTD
        Model: MacBook Air (Retina, 13-inch, 2020)
        Serial Number: FVFCXXXXXXXX
        Find My Mac: OFF
        • kino0924
          • Jan 2023
          • 12
          https://boards.rossmanngroup.com/thr...ecovery.63410/
          I found similar problem of 0x3FFF
          1. SSD problem
          2. Naked board (I may still have problem with trackpad/keyboard which is causing the problem)
          I dont have any spare macbook or parts to test 2nd option.
          Is there any ways to test bad SSD with bare board?
          • kino0924
            • Jan 2023
            • 12
            Minor update
            I got USB-C power meter and I confirmed that the board jumps to 20V
            • thedoger82
              • Jul 2017
              • 24
              • colombia
              I got the same exact error in a iwatch... i havent found any solution yet... yourself?
              Thanks!!!
              • mon2
                • Dec 2019
                • 14740
                Meter in dc volts scale (20v or higher is ok).
                What is the voltage to ground of ppbus_g3h ?
                what is the current draw and voltage reading on your usb C meter? Is the current draw fixed and immediate or climbs up to the current value?
                • Darren Hibbert
                  MacBook A2179 Audio board+Power button boardview & schematic needed
                  by Darren Hibbert
                  Hi.
                  Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
                  There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
                  Many thanks. ...
                  08-21-2025, 02:38 PM
                • thuygsm
                  Macbook Air 2020 A2179 820-01958 (5V to the USB-C port unstable)
                  by thuygsm
                  I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port unstable).
                  I noticed there is liquid at U3200 and U3100 and have replaced them.
                  PP1V5_UPC_X_LDO_CORE : 1.575V
                  PP3V3_UPC_X_LDO : 3.280V
                  PP3V3_G3H_RTC: constantly fluctuating from 0.5V to 3.284V
                  I have isolated R6979,
                  Pin 1: 3.280V stable
                  Pin 2: 0.447 (diode)
                  PPBUS_G3H: 12.28V (with R6979 isolated)
                  PPBUS_G3H: fluctuates 5V -> 4V -> 6V -> 12.28V(when R6979 is present), and repeats in a loop
                  What should I do next?
                  10-29-2025, 06:02 AM
                • jesi
                  macbook pro a1707 dead
                  by jesi
                  hi all techs
                  require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
                  adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
                  update:
                  when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                  08-24-2025, 04:34 AM
                • robka
                  MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                  by robka
                  my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                  I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                  The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                  After that the Macbook was dead. It isn't charging anymore.
                  The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                  03-02-2024, 02:58 PM
                • Rav_tangle
                  MacBook Pro 2011 turns on with keyboard light , screen dead
                  by Rav_tangle
                  Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                  I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                  Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                  is this...
                  05-31-2024, 04:09 PM
