820-00165 Charging Problem
  • Instafixx
    • Jul 2022
    • 374
    • India
    I have a Macbook Air A1466 820-00165 which has a weird problem.
    The Macbook came in for a charging problem but we put the charger and it started charging. We suspected that it maybe a charging issue but the Macbook intermittently charges from different chargers.
    One Observation : Whenevr we connect it to a DC power Supply (Input 15V) it charges and post that it will charge from a normal charger too until one day it wont charge and then again have to plug in the DC Power Supply.
    Anyone can guide me on this?
  • reformatt
    • Feb 2020
    • 1511
    Re: 820-00165 Charging Problem
    I've seen this with genuine magsafe chargers. Non genuines work fine though because they don't use any load sensing to switch through the power.
    Check R7012 value, then check for residual voltage here with battery connected and no charger connected. Usually it's a leaky Q7180 allowing battery voltage back into this area, which messes up the load detection of the genuine Magsafe chargers.
    • Instafixx
      • Jul 2022
      • 374
      • India
      Originally posted by reformatt
      i've seen this with genuine magsafe chargers. Non genuines work fine though because they don't use any load sensing to switch through the power.
      Check r7012 value, then check for residual voltage here with battery connected and no charger connected. Usually it's a leaky q7180 allowing battery voltage back into this area, which messes up the load detection of the genuine magsafe chargers.
      currently not charging with a genuine magsafe charger
      battery out
      meter in 2k mode
      resistance at pin #1 of r7012 is .648.
      What should i do now?
      • mon2
        • Dec 2019
        • 14677
        How many charge cycles on the battery ?
        Is the battery the original?
        Test with another known good battery.
        • Instafixx
          • Jul 2022
          • 374
          • India
          Originally posted by mon2
          how many charge cycles on the battery ?
          battery cycle count is 294.
          Yes it is an original battery.
          Right now its charging well even with the original chagrer.
          So how do i swap any part and be sure that it is a part issue? Because the charging issue is intermittent.
          Only thing which i am sure of is that whenever it doesnt charge from a genuine magsafe charger, we have to connect it tohe dc power supply post which it is back to normal for sometime.
          • mon2
            • Dec 2019
            • 14677
            Measure the voltage to ground of ACIN pin #3 of U7100.
            What is the voltage when using the original adapter that is flaky with the charging?
            What is the voltage when using the working dc power supply?
            Also post the voltage of PPDCIN_G3H_ISOL.
            • Instafixx
              • Jul 2022
              • 374
              • India
              Pin # 3 of U7100 is 3.3V
              Voltage of PPCDIN_G3H_ISOL is 15V.
              On both the flaky charger and the DC Power Supply.
              • mon2
                • Dec 2019
                • 14677
                See attached.
                Measure the voltage to ground of:
                source (1-2-3)
                gate (4)
                drain (5-6-7-8)
                pins of the battery mosfet @ Q7155 when:
                a) using the non-working / flaky original charger - interested in the voltage readings when the battery is NOT charging
                b) the battery is charging with your DC power supply
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  See attached.
                  source (1-2-3)
                  gate (4)
                  drain (5-6-7-8)
                  So somehow it is working till now from the Flaky Chagrer too hence cannot measure the Voltage when it is not charging. Hence checked with the charging ON.
                  with Flaky Charger
                  Q7155
                  Pin#1 8.58V
                  Pin # 2 8.57V
                  Pin # 3 8.58V
                  Pin #4 7.87V
                  On the right side there are 4 Points but the schematics has only 1 hence posting voltages of all 4 from top to bottom. Top Point is close to the battery connector
                  A Cycling from 0.3 to 8.58V
                  b 8.58V
                  c Cycling between 0.3 to 8.58V
                  d Cycling between 0.3 to 8.58V
                  All voltages on the flaky charger while its charging. Battery Not Connected.
                  • mon2
                    • Dec 2019
                    • 14677
                    Now add the battery and measure these points again.
                    • Instafixx
                      • Jul 2022
                      • 374
                      • India
                      With Battery On and Charger On (Flaky) and charging.
                      Q7155
                      Pin#1 8.58V
                      Pin # 2 8.57V
                      Pin # 3 8.58V
                      Pin #4 1.2V
                      A 8.58V
                      b 8.58V
                      c 8.58V
                      d 8.58V
                      Note that the battery is at 100 charge and the charger is showing a green light.
                      • mon2
                        • Dec 2019
                        • 14677
                        Yes, right side of this mosfet has the drain pins = pins 5-6-7-8. Any of these pins can be measured since these block of pins are mated together. See the datasheet or the bottom side of these mosfets. You will see a solid connection between these pins.
                        The gate voltage defines if this mosfet is on or off. Being a P-channel mosfet, the gate voltage must be lower than the voltage it is passing between the source and drain pins.
                        So if gate is a high or same voltage as the source / drain pins, the mosfet should be off.
                        Of concern is that you do not have a lower voltage on the gate pin when the battery is removed, yet drain has the same voltage as the source??
                        That is, the drain pins should be at 0 volts for this case.
                        Remove all power. Remove the battery. Meter in resistance mode.
                        Measure the resistance across this mosfet's pins:
                        Source & drain ; select any of the pins (1-2-3) and (5-6-7-8)
                        Source & gate (4)
                        Gate & drain
                        Post the resistance of each measurement. If the resistance is low on any of the above checks, the mosfet is leaking and should be replaced.
                        Suspecting that this mosfet is defective from your measurements without the battery.
                        • Instafixx
                          • Jul 2022
                          • 374
                          • India
                          Source & gate (4)
                          Gate & drain
                          Meter in 2K Mode
                          Black Probe on Source and Redon Drain .367
                          Black Probe on Source and Red on Gate .705
                          Black Porbe on Gate and Red on the Drain 1
                          i hope gave the right measurements.
                          • mon2
                            • Dec 2019
                            • 14677
                            Can you post a pic of your meter face?
                            Appears that the same button may be also with diode mode?
                            If yes, keep pressing the mode button till you see the omega symbol. Post a pic to clarify.
                            • Instafixx
                              • Jul 2022
                              • 374
                              • India
                              Its a Analog Meter.
                              • mon2
                                • Dec 2019
                                • 14677
                                No, meter is digital. The 2k scale also is the diode mode scale.
                                Press the yellow button to switch to the resistance mode scale.
                                Then measure again. If you do not get a proper reading, switch to the next higher resistance scale.
                                Post your readings again.
                                Check resistance between,
                                Pins 1 & 8 = source & drain
                                Pins 1 & 4 = source & gate
                                Pins 4 & 8 = gate & drain
                                • Instafixx
                                  • Jul 2022
                                  • 374
                                  • India
                                  The Yellow button just switches on the Backlight.
                                  Used another Digital Meter. Pressed the button till i got the Omega Sign on the screen . Picture attached.
                                  Black on 1 and Red on 8 = 2.12
                                  black on 1 and Red on 4 = 8.31
                                  Black on 4 and Red on 8 = 8.82
                                  • mon2
                                    • Dec 2019
                                    • 14677
                                    Can you a pic of the meter face with one of these measurements?
                                    Is the reading in M ohms? That will be then (for example) 2.x megaohms but we need to confirm each.
                                    When you short the meter probes, the reading should be ~0 ohms.
                                    • Instafixx
                                      • Jul 2022
                                      • 374
                                      • India
                                      Yes its M Ohms.
                                      One strange thing is that while taking the measurements again i am getting
                                      Black on 1 and Red on 8 = 848 k
                                      black on 1 and Red on 4 = 8.33 m
                                      Black on 4 and Red on 8 = 6.2 M
                                      • Instafixx
                                        • Jul 2022
                                        • 374
                                        • India
                                        Also sometime 4 and 8 is =0 ohms~
                                        • brockauly
                                          Macbook M1 A2337 EMC 3598 weird battery charging problem
                                          by brockauly
                                          Hi guys,
                                          If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
                                          Then if I unplug the charger and plug it back, it won't charge anymore.
                                          In the first case, main voltage is regulated at ~12.5V and charges the battery.
                                          After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
                                          After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
                                          I found C520A (2.2µ after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
                                          02-05-2025, 10:51 AM
                                        • drlarsen
                                          MacBook Air M1 A2337 battery/charging issue
                                          by drlarsen
                                          Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                          I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                          On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                          After some hours, the battery status did not improve. Restore via DFU did not help.
                                          I connected the power adapter to a Kill-a-Watt...
                                          07-17-2025, 02:35 PM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ahmarzo
                                          Hp laptop charging problem
                                          by ahmarzo
                                          Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
                                          Charging ic is bq737 with voltages on pin no
                                          1&2 -19v
                                          34&5 -0v
                                          6 -2.56 v
                                          7- 0v
                                          8&9 -3.15v
                                          10 -0v
                                          11 -0.18v
                                          12 & 13 -13v
                                          14&15 -0v
                                          16 -6v
                                          17;18&19 -13v
                                          20 - 19v
                                          Voltages on battery connector are
                                          1&2. -13v
                                          3&4 -3.14 v
                                          5&6 -0v
                                          8&9 are ground...
                                          03-20-2025, 05:13 AM
                                        • Gueric
                                          Macbook Pro M1 (A2338) 820-02020 not charging.
                                          by Gueric
                                          I returned home from college. My MacBook battery was flat. Plugged it in. Nothing. Won’t boot. Waited for an hour. Nothing.
                                          When plugging the charger : 20v at 0.02 amps.
                                          pressing any key will make the « low battery » icon show up. Then switch to 5v and 420mA constant. Trackpad clicks, keyboard works.
                                          Decided to put the board into another M1 body with a charged battery, it’s booting perfect, still 5v and 420mA tho, and battery is not charging.
                                          I diode moded every pin of U5200 and they’re all fine. I know very little about Apple silicon machines...
                                          07-23-2025, 01:54 PM
