PS5 HDMI capacitor
  • Eniaro
    • Mar 2021
    • 77
    PS5 HDMI capacitor
    There's a capacitor located directly behind the HDMI port that seems to get knocked off whenever the HDMI port gets damaged
    does anyone know the correct value of this cap
    eBay says
    100nf/ 0.1uf 16v 0201 Capacitor SMD
    iFixit & Reddit
    0201 0.1UF 10V
    iFixit and Reddit posts, reference their source to kasynparts
  • diif
    • Feb 2014
    • 6978
    • England
    Re: PS5 HDMI capacitor
    It's decoupling 5v, either will be fine.
    • Eniaro
      • Mar 2021
      • 77
      I went with 16v seems to work well.
      Thank you
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
