playstation 5 digital firmware dump
Could someone help me out looking for a 1115B or this one to be fixed? I tried a 1116A no luck on it. Turned into a no power no beeps. I reflashed to this but still 3 beeps
Thank you!Attached FilesLeave a comment:
hello all. I've tried many different bios files for my 1015A disk edition, edm010. to no success. the most recent one i used another IC from a 1015A and used that NOR modifier to change serial..making sure i chose 1015A and DISK. console turns on and sometimes takes the disk and copies it, then it wont accept a disk at all... im really lost at this point, this seems relatively easy, but i must be missing something... I'd like to be able to use my original BIOs file and just fix whatever error is there, but i've no clue. any help would be GREATLY appreciated
What is exactly the problem and what is the error message from the disc drive?
If your disc drive is accepting disc but have trouble to read it and shows the error "Can't recognize...", the laser is mostly done.Leave a comment:
hello all. I've tried many different bios files for my 1015A disk edition, edm010. to no success. the most recent one i used another IC from a 1015A and used that NOR modifier to change serial..making sure i chose 1015A and DISK. console turns on and sometimes takes the disk and copies it, then it wont accept a disk at all... im really lost at this point, this seems relatively easy, but i must be missing something... I'd like to be able to use my original BIOs file and just fix whatever error is there, but i've no clue. any help would be GREATLY appreciatedLeave a comment:
I've flashed a CFI-1016A, now PS5 boot but it won't to update with error su-101217-2, I've seen it has no wifi MAC Address.
What can I do?Leave a comment:
i have ps5 disk version cfi-1216a edm-031 61gg with 3 blodAttached FilesLeave a comment:
To reconfirm your PS5 BIOS file, use the PS5 Nor Modifier to obtain details like the MAC address and serial number. Then, obtain another BIOS file, whether digital or on disc, and place it in the PS5 Nor Modifier. Take note of the data serial number and use a hex editor to modify the new BIOS file. It's preferable if the new BIOS file is the same model as your own.
In the hex editor, use your main BIOS file as the source to edit the new BIOS file.
Insert:ThumbnailSmallMediumLargeFullsizeRemove
Sc
Then, use the PS5 Nor Modifier to verify if the serial number and MAC address have changed. Finally, choose the model and edition to generate.Leave a comment:
Hello still looking for cfi-1015b edm-010 bios firmware digital edition. Can anyone help with that?Leave a comment:
Please share Bios for CFI-121A. Tried one in the tread, showing invalid file error on PS5 NOR Modifier. Please helpLeave a comment:
Need help with, edm-040, cfi-2015.
Getting:80801F12 Known Unknown 80801F12 (Kernel) - Report Findings - 1 sec blue light
any leads would be appreciated with the fix.
Ps5 draws: .2 - .3 and lowers to .07 Amps.
During this stage,
1. cxd90069gg ( southbridge ) heats up to 35c
2. RT5126 heats up to 30c
3. Da9081 heats up to 30c
No shorts found on the main board.
Any idea or leads ?Leave a comment:
Hello Guys,
Hope you had a wonderful day.
I am in need for a nor dump for CFI-2015, Digital version. EDM-040. existing nor is damaged.
Any help would be appreciated.
Thank you.Leave a comment:
Anyone have bios file for 1215a disk version? Have 3 beeps no power...Leave a comment:
Still having problems with a PS5 "can't connect to server to verify licenses", tried restoring licences via system menu but it throws up an error code two thirds through (error code CE-105628-2) anyone have any ideas to a solution? tried resetting console, reinstalling systems software via USB etc, the console will install and play games via disk with no problems, it's only games downloaded from PSN that throws up the error & won't start the games, the console updates fine.Leave a comment:
cfi-2016 3 beeps NO POWERLeave a comment:
Thank you rui4892, I have downloaded the Nor modifier so will give it a try, I'm not sure if changing the serial number will work or not seeing as the NOR & matched disc drive were from another console, only one way to find out, I will let you know how it goes, many thanks for the info.Leave a comment:
Need further help, I've got a PS5 disc edition EDM-020 that had the NOR IC missing when I got it, I got it back up and running by using a bios/NOR IC & matched disc drive from a scrap console, however although the disc drive works fine and I can install & run games from it, if I download a game from PSN when I try to run it a error comes up saying "can't connect to server to verify license", I'm guessing that because the NOR is not matched to the APU/serial number, if this is correct then how do I change the serial number on the NORLeave a comment:
