playstation 5 digital firmware dump
  • murshad
    replied
    hey i have this ps5 for repair it shows error su-103121-8 it came up with drive controller chip so i saw the cod3r was doing that disk edition to digital edition via just rewriting a digital versions bios for try need working bios of a digital version and ,odel number is CFI-1208A
  • Karlhartl
    replied
    Hi Guys, i have this CFI-1200A EDM-030 69GG firmware 9.20 donor dump needed please anyone help out
  • techcity
    replied
    Originally posted by eznacho
    Need CFI-1215B EDM-030 digital version. Thanks in advance.
    Did you ever find this? I am also looking for this file. CFI-1215B EDM-030
  • Xtristi x
    replied
    Originally posted by Unspun01
    Hi. I read this entire thread, and I need to ask - Besides reading the NOR, and flashing contents back to the NOR, is anyone actually writing all ZEROS (00) or all ONES (FF) to the NOR to see if their actual NOR chip is actually good? Many people using this thread seem to be downloading NOR dumps, or reading/patching and writing to their NOR chips without seeing if the actual chip is working properly.
    Some of the posts on here even say they read the NOR, and re-programmed the NOR with the same .BIN file and it seemed to work. This tells me the NOR chip might be dodgy, and may lead to another future failure.
    Can anyone here provide some testimony that they have tested NOR chips by writing all 00 or all FF back-to-back and VERIFY if the contents of their NOR chips actually match exactly what is expected?
    If even one bit does not verify it could cause issues and hints at a possible bad IC.
    So far, I have not seen any evidence that anyone is verifying their NOR performance, or that the contents they are programming are accepted bit-for-bit on the IC itself.
    Not criticizing anyone. I just genuinely want to know if the NOR contents corruption is a software issue, or a hardware issue.
    As others in this forum have cautioned, we should not just download random things from the internet (due to console specific things like serial number, LAN mac address, WIFI mac address, disc or discless, any many others) without knowing what the risks are. Many people may have good NOR contents but the chip is not working correctly.
    Hope to hear some other people's experiences.
    i know my revelprog the will verify contents match uploaded or saved vs actual eeprom data. So I'm sure it's all up to the person or program that is being utilized. At the same time using an oscilloscope and verifying clock and data transfer from Southbridge to the chip will verify whether or not things are working as intended IC wise.
  • Unspun01
    replied
  • cr8179891
    replied
    Originally posted by crasher381
    I'm about to replace the HDMI port on a cfi-1215a edm-033 69gg board, I attached the file here in case you want to try it.
    thank you dude, this saved me on a cFi-1215a with 3 beep, took a few writes for it to take but it fired up.
  • AgentNovac
    replied
    Originally posted by Cobbes
    Check what southbridge is on your cfi-1216a edm-030
    After start, check if WiFi is working and showing its MAC in system infos.
    YOU ARE AMAZING! THANKS SO MUCH! IT WORKED!!!
  • Cobbes
    replied
  • AgentNovac
    replied
    Hi, I need bios for cfi-1216a edm-030 please
  • T.K.
    replied
    Originally posted by M11111
    i have a PS5 bios bin ? EDM-040, CFI-2016 ......thanks
    can i get that!
  • T.K.
    replied
    Hi Guys, hoping to get a bios dump for a PS5 CFI-2015-040
  • pacwcbs
    replied
  • Xtristi x
    replied
    Why was my post deleted then? I was never in contact with BWE ever? check my messages I haven't received a single one ever on this platform, well mostly because I forgot to introduce myself like 8 years ago😂. Nor has he ever told me to endorse his product? It was a legitment fix to a problem. I mostly lurk here as you can see my account age vs posts as most have been answered when finding problems using this forum, this particular question hasn't been and he had a legitment solution, to which I ended up finding myself as his comments were always deleted before anything. The practices here aren't even the best or rely on copying data with zero procedures described and doing things blindly using other consoles data. I'm not shilling his products, its literally a solution to a problem and worked perfectly. Honest question, how would we go about helping others if the best/easiest solution for a diy'r is a cost effective paid service? Should I not reference them at all? I know you have strict rules about endorsement, but who has actually posted anything in this thread that would lead to fixing a Nor file? Other than copying someone else's data and flashing it, which is more a work around vs an actual fix? Probably as to why people here are now having issues with mac addresses and wifi modules not working because they are just flashing addresses from other consoles.
    On a side note I know he's not very accepted in the community because of his semi unsightly business practices as seen before, But if its a legitment fix, why not tell people there is a way?
    If this sort of thing isn't accepted then my apologies, truly. But it was an actual solution to my problems, and I feel like people could benefit.
  • BwE
    replied
    deleted by admin and user banned for 7 days. not specifically for these posts but because they contacted users shilling their software after being told not to
  • BwE
    replied
    [QUOTE=Xtristi x;n3580179]
    edited by admin... you can not post your software or other adverts on this forum.
  • Aiman_saad
    replied
    Hi Everyone
    Does anyone have the BIOS file for a PS5 CFI-1115A EDM 020 DISC Version?
    Thanks​ in advance
  • Xtristi x
    replied
    Originally posted by BwE
    You know you shouldnt use other peoples dumps, it overwrites per-console data. You're better off repairing it or making an entirely new one from scratch whilst using data from the original as a donor.
    How would you go about repairing your existing nor read? I'm just trying to fix my own console. Shelling out 100+ dollars for your utility to use it once isn't exactly in the cards.
  • BwE
    replied
  • Darky777
    replied
    Hello.
    I have a Playstation 5 that doesn't turn of after change from disc edition to digital, any advice will be appreciated
  • happyllama
    replied
    Hey, does anyone have a BIOS dump for CFI-1208A?
    Thanking in advance!
