Glueing Two Sided Flex Ribbon,Jaguar XJS Instrument cluster.
  • JayPoorJay
    • Jan 2022
    • 149
    Hello All.
    I'm working on the printed flex circuit board (flexible type) of a 1990 Jaguar XJS Instrument cluster. If you Google that you'll be able to get a general idea.
    In areas, the plastic has come apart allowing the copper strip to kinda flop around and be exposed to the elements.
    What can I use to glue the 2 faces of the plastic material together trapping the copper ribbon inside...
    Again - thank you all for you help. This will be the 4th or 5th time now that I have come here to receive AMAZING advise and directions. Thanks so much!
  • Papa Gleb
    • Apr 2022
    • 7
    Re: Glueing Two Sided Flex Ribbon,Jaguar XJS Instrument cluster.
    Hey If you are trying to glue plastic together then any glue will work. If you are trying to glue the actual flex cable then I would say hot glue would be the safest option. You can even use it to cover whatever is exposed. I googled it and it appears to be a big flex with many traces. What exactly are you trying to glue and are you sure it doesn't need to be soldered?
    Please attached pictures.
    • JayPoorJay
      • Jan 2022
      • 149
      Hey Gleb...
      Basically the two halves of the plastic ribbon have come away from each other at a few sections, and it's getting worse. This particular area is all B+ 13+ volts, so I need it tied down with something non conductive, that will hold. There should be any heat involved other than the heat and cold that the interior of a car will experience thru seasons. Was looking for an adhesive for this. Will send some snaps
      The other issues, yes, some pictures and diagrams will be forthcoming. Now that I GOT ya, lol...
      • redwire
        • 3910
        The original flex is a sandwich of plastic, adhesive, copper formed under high pressure and heat in a press. Guessing mylar film (not darker coloured polyamide) and adhesive similar to DuPont Pyralux LF but it only comes in sheets. I couldn't find any glues for repair.
        Cyanoacrylate (Super Glue) does not stick to some plastics or metal, you'd have to do a test but I think it's not good.
        People solder in jumper wires to bypass the flex cable but soldering it melts and wrecks it. Instrument cluster should not have high current beyond needing to clear a fuse if there is a short circuit.
        • JayPoorJay
          • Jan 2022
          • 149
          HellO Red. Ok, I see the link. And I like your thinking. I have some super glue on hand I just was sure whether it was conductive or not.
          I'll post up some photos, feel a bit ashamed of what I'm working with, but... Time and age did this, not me, lol. I have destroyed anything,,, yet 😆
          • diif
            • Feb 2014
            • 6978
            • England
            I would use B-7000 rather than super glue as it has a little flex.
              • Jul 2011
              • 6039
              This might work but have never tried this but it might be worth a try if the plastic has come loose from both side of the trace then why not use full sheet of laminating that is use to laminate full sheet of paper that you want to keep
              I do not see any reason why this would not work however if someone does feel that this would not work feel free to explain to me why this would not work
              it might not be as strong as the original one is but it might still be good enough to keep using the cluster unit until you can maybe find a replacement for it
              ( I would only repair the sections that are bad I would not try to peal off sections that are not separating )
              ( if the copper trace is torn they do sell copper strip on a roll in different diameters which can be replaced and join back together with soldering them back together )
              I would clean the copper until it shines before I would laminate it back together if this should work please let me know how it turns out
                • Jul 2011
                • 6039
                Originally posted by JayPoorJay
                I'll post up some photos, feel a bit ashamed of what I'm working with, but... Time and age did this, not me, lol. I have destroyed anything,,, yet ��
                Do not feel bad about the hand that you are dealt with because you have no control over the issues that are present sometimes you have to think outside of the box for a solution to fix the issue
                You can try to find a junkyard that has a watt line that can get in touch with other junkyard to find a replacement unit for you just have to ask if they have this service ( most of the time they are junkyards that are not you pull your own parts and you will have to pay more for this service because the part has been already been pulled )
                Here is one I think that I might have used in the past to hard to find parts
                https://www.fenixparts.com/
                There are a couple of them here in Jacksonville FL I have used them before for parts that are very hard to find
                Here is another place that you can try I personally have not bought from them so I can not recommend them
                https://www.partrequest.com/catalog/...uar/jaguar-xjs
                Go to this website page
                https://www.partrequest.com/request/parts/5629f92e27af
                I hope this helps you
                • CapLeaker
                  Leaking Member
                  • 8155
                  We’ve got something called shoe goo. It sticks like mad, but stays flexible.
                  • JayPoorJay
                    • Jan 2022
                    • 149
                    Ha! I remember shoe goo. Was a good thing when it came out,,, 80s I think...?
                    So, I used a combination of super glue (which I liked) and the E6000 (which I know think is a knock off of another product) which reminded me a lot of shoe goo. All good results. The super glue DID make for stiff sections (which wasn't a bad thing in some areas) and the 6000 in areas that MIGHT get bumped or moved. All good. I reinstalled the instrument cluster last night and drove into work this morning.
                    Replaced many lights with LEDs. Great improvement. Dealing with the polarity was not much fun.
                    Still. No speedometer...
                    Is anyone in this thread willing to help with that.
                    I'd be happy to post what information I have in it.
                    Which ain't much.
                    Either way,,, thank you ALL for your help, guidance, advise, suggestions... Helped me sleep better at night.
                    Oh! About replacing the cluster. I have 4 old cars. Sometimes I have to bite the bullet and replace things outright. Scouring the world over for bits and pieces... But I try to hold off unless absolutely no alternative is possible. One, I like fixing stuff and TWO (the big one,,,) I ain't a rich man. So it goes
                    Thanks again good people!
                    And let me know if you'd be interested in the speedometer issues
                      • Jul 2011
                      • 6039
                      If you post some pictures of the speedometer I might be able to help you with it but I have to see what you have the more detail on the picture the better
                      I have repaired one on my 1995 Ford Range once before and on another car before
                        Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                        09-07-2024, 07:20 AM
                        09-07-2024, 06:38 AM
