Re: Fixing a laboratory waterbath
Rule #1 of resistance measurement : You cannot measure resistance of a component when it's in circuit. Thus you cannot make any conclusions of resistance values taken when devices are in circuit.
Yes effectively MT1 and MT2 will be connected together in a TRIAC when gate is triggered and will remain so until the current going through drops below the threshold.
I wrote in my previous post that it was fixed (I removed that part). That's not the case. There was just a bad connection with the heating element. The resistance between MT1 and MT2 is 17 Ohms.Leave a comment:
It goes GATE MT2 MT1. GATE is connected to the transformer that is connected to the control PCB. MT2 is connected to the heater. MT1 is connected to 120V. I m not sure my understanding of the TRIAC is correct. My understanding is once the GATE is activated by a current (from the control PCB), MT2 and MT1 are activated. When the TRIAC is activated, MT2 and MT1 become connected in the TRIAC, forming a closed circuit and allowing current to flow from MT1 to MT2 to the heating element. Maybe someone can confirm this.
The TRIAC is an NTE56010. 800v and 15A. It s the same as the original one.Last edited by vrasp; 07-22-2021, 02:19 PM.Leave a comment:
What is the resistance between MT1 and MT2 with out the triac and the heater element installed because this is what going to matter as far as the triac output is concerned
Correct me if I am wrong but is MT2 is the output of the triac if this is the case then you also need to check the resistance between the output side of triac and the neutral side of the power supply cord
Because either you have an issue with the heater element or something in this controller output from the triac output that is causing this issue blowing up the triac
Here is something I would do but be very careful doing this you need to check how much current the heater element is drawing by itself
Also put a incandescent light bulb on connections for the heater element and see what type of amperage you have on MT1 a 100 watt incandescent light bulb should be about 2 amps or so but check how much amperage your incandescent light bulb is drawing current because the two should match other reading
What is the gate voltage for this triac because if this is not correct you could be not turning the triac completely ON or the voltage is to high on the gate pin you need to look at the data sheet for this triacLast edited by sam_sam_sam; 07-22-2021, 12:20 PM.Leave a comment:
I read that the TRIAC should have a high resistance between MT1 and MT2. Does that apply when it s in the circuit as well? I was measuring the resistance between where the terminal of MT1 and MT2 connect, so I m measuring on the board and trying to see why there is a low resistance. If this statement only apply to the triac off circuit then maybe it doesn't matter that the resistance between MT1 and MT2 is low on the PCB.
I dont know why the TRIAC shorted again and this was the investigation I was doing because I cant think of any other reason. The TRIAC was not grounded. I checked many times and with each pin and the metal plate too.Leave a comment:
not sure what you're trying to measure here...
All that matters is that you don't exceed its rated current/power dissipation/voltage limit. And when you measure resistance of the TRIAC it needs to be measured out of circuit.Leave a comment:
I removed the primary of the toroidal transformer which supplies 8v, 20v, and 15v on its secondary to the board below and the display board. Now the resistance between hot and neutral is ~20-23 Ohms.
This means that if I were to install a new TRIAC, it would have about 23 Ohms between it's MT1 and MT2. Is that ok for a TRIAC?Last edited by vrasp; 07-22-2021, 10:39 AM.Leave a comment:
The triac is rated at 15 amps. However it worked before. I think the resistance between hot and neutral should be higher.
I have a very high resistance between the heating element and ground and ~13 Ohms between hot and neutral of the heating element. From what I read this is a normal value for a heating element.
I ll try removing each element on this board until I get a high resistance between hot and neutral. There is the transformer and some smaller components I havent tried removing yet.Last edited by vrasp; 07-22-2021, 10:03 AM.Leave a comment:
What is the specifications of the triac that it has
Really 120 volts @ 5 ohms = 24 amps if your triac is not rated for that then you would fry them
Check the heater element by it selfLast edited by sam_sam_sam; 07-22-2021, 09:52 AM.Leave a comment:
I m getting ~5 Ohms between hot and neutral with the heating element disconnected (and no triac since it has been removed). There isnt much left on that line so it should be easy to find.Leave a comment:
One thing that can happen with heating elements is they can short to ground when they heat up, the internal element expands and in some cases breaks through the insulation and shorts. This can burn a hole in the element but not always. You can try insulating the element from ground and disconnect its ground wire if it has one to test this.Leave a comment:
I actually had already checked the heating element with ground and it was fine. All three terminals had high resistance with ground.
I m thinking of everything thats on the board. I ve already removed the capacitor. I m pretty sure it s not the transformer. I can try removing it. The rest are part of the circuit that feeds the pcb below it so not related to the actual heating.
Isn't a heating element just a thick tube of copper/alloy with a high current going through it? How could it be faulty?
Below is a photo of the board I ve posted before.
Next to the number "12" is in order
Gate
MT2
MT1
I made a mistake in my previous post. MT1 terminal is connected to the heater element and MT2 terminal to 120V. Either way, there is continuity between them where there shouldn't be.Attached Filesif you find these attachements useful please consider making a small donation to the site
If the heater element is like the type in a water heater then you need to check the outer case to the terminal of the heater element and you should NOT get any resistance if you do have any resistance then there is an issue with the heater element
What is the resistance of the heater element because if it is for 120 volts then the resistance can not be extremely low because if this might be your problem ( it should be around 8 to 10 ohms )
This also depends on the tirac amperage rating if it lower than 15 amps then your resistance would be higher than 10 ohmsLast edited by sam_sam_sam; 07-21-2021, 04:17 PM.Leave a comment:
Or there is a very low resistance between neutral and live. I ll check that.Leave a comment:
I plugged waterbath straight into the wall without the bulbs in series. The TRIAC blew again. It was not grounded, I checked.
These are the observations I made:
The resistance between where MT1 and MT2 connect have a low resistance (even with no TRIAC connnected). Based on my reading, it is supposed to have a high resistance. From now on I ll refer to where MT1 and MT2 connect as MT1 and MT2 to make things easier. MT1 connects to the heating element. It's the live of that heating element and then there is a neutral wire that goes from the heating element to the PCB. MT2 connects to 120V.
I removed the heating element cable from MT1 and the resistance between MT1 and MT2 became very high, which makes sense since MT1 is only connected to that. Could a faulty heating element cause that? I don't see how but I don't know.
Any ideas?
Thank you!Last edited by vrasp; 07-21-2021, 03:16 PM.Leave a comment:
It's up to you to decide what's going on... especially when dealing with heaters and other things that draw a lot of power.Leave a comment:
I tried with 3 bulbs this morning. They all light up. I dont think they re at their full brightness but I m not 100% positive. They do get very hot.
I noticed the voltage drop across the primary of the transformer is about 65v. Is it normal for these bulbs to drop the voltage by that much?
The waterbath temperature increased by 0.5 degrees in 20 min. So it slowly heats up which would make sense with the limited amps and lower voltage.
I m not confident everything is working well enough to plug it without the bulbs.Attached Filesif you find these attachements useful please consider making a small donation to the site
Yes unless you have to many lights bulbs then would almost as though you were using a fuseLeave a comment:
No pressure here. We use a mixture of water and anti-freeze. It allows us to get to temperatures below 0 and a bit higher than 100 °C. We almost never use it at such high temps anyways. If we wanted to we d have to use another mixture. We do use it at temperatures below 0 though.
Yesterday I made myself a small current limiter setup with a 100w bulb. I tried it today with the waterbath. The waterbath starts and runs but the display is dim and the pump fan turns slower than it should. Also the bulb is bright. I suppose it needs more amps to run properly.
Tomorrow I ll try with 2 bulbs or more. If I understand well, if I can get to a point where the bulbs are dim and not at full brightness, I can confidently assume that there is no short. Otherwise, if after adding a few bulbs they re still really bright there is probably a short. I don't know how many amps the load normaly takes but since there is a heating element I think it's likely at least a few amps. What do you think?Attached Filesif you find these attachements useful please consider making a small donation to the site
by learnmoreHello Community,
I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
Peace
LM...11-04-2025, 09:35 AM -
by ohrenHello!
I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
Measured voltages with no load:
After rectifier diodes
12V: 6.17 V
5V: 5.67 V
Secondary transformer pins AC measurement (really don't know if this says anything)
12V: 2-2.5 V
5V: 1.04 V
I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,... -
by mikey5791Hi all,
Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
My questions are
1. How do i test to see if the transformer is in good working condition?
2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
Hope you guys understand what i was asking. My intention is... -
by dennis_elx33Hello All,
i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
Problem statement: Power tripped Off
Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
Action Done:
1) Replaced the faulty parts with good spare.
2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will... -
This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 04:40 PM
- Loading...
