Kitchenaid food processor burnt wire
  • pulper111
    • Aug 2017
    • 39
    I'm trying to fix my kitchenaid food processor KFP750WH. The on button will press properly and the light will go on, but it will not run.
    I've experienced this before and taken it apart, and previously there would be a connection that simply disconnected. I would reattach it and it would be fine. Now, that connection is burnt and partially broken off.
    I put a few pictures here. I have no problem getting my hands a little dirty but can't figure out the best way to remake this connection. The male part where it attaches seems to have a little coating from the plastic from the wire (female) attachment. I'm assuming i can scratch this coating off. The female connector is unfamiliar to me with regards to naming it and getting a replacement, if possible.
    thanks for any help.
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: Kitchenaid food processor burnt wire
    i would fit a new blade and spade connector and push them together and then solder them together .
      • 31281
      it's just a spade connector in a plastic housing.
      you can just crimp an insulated one onto the wire
      find out the width of the tab though, they come in different sizes.
      the common ones are 4.8mm and 6.something
      and the insulated crimps usually come in red, blue and yellow - the colour indicates the maximum wire diameter.
      you can probably get them anywhere that sells stuff for cars - even a gas station
        • Jul 2011
        • 6070
        No go to a appliance repair shop and get the high temperature blade crimps the are used on compressor terminals or stove type of crimps will also work if they fit they also come in two sizes
        The ones that are used in automotive use are not ( high temperature terminals ) —> ( heavy current use devices )
        You will have to use heat shrink tubing because as far as I know they do not come that way
        One note this type of crimps are harder to crimp than automotive type crimps and they are made differently
        You just need side cutters to close the crimp tabs depending on which stile that you can find
        I hope this helps you
        • pulper111
          • Aug 2017
          • 39
          What a great community here! such quick answers and help. I appreciate it.
          It's not easy to measure but it looks like the male tab is approx 0.25".
          A couple of questions still:
          1. Would this be a good recommendation, considering the internal heat?
          https://www.amazon.com/Supco-T1111-D...ustrial&sr=1-5
          2. for heat shrink, do I just do this around the small hole (where the wire goes through) or do i need to heat shrink the entire area?
          Thanks!
          • redwire
            • 3912
            Gently scrape off the melted plastic from the relay terminal and I would put on a new crimp connector, something not from china where the metal is thin-not copper, plating is crap and the spring is flat.
            From the pic is #18AWG 105°C wire, KFP750WH is 700W around 6A.
            I use TE Connectivity 1/4" or 6.35mm terminals from Mouser (no.. Texas storm now) or Digi-Key. The Amazon part looks OK but it's from china, nothing great.
            You can put a piece of heatshrink or silicone sleeve over the connector and wire. The old cover that is melted, could cut off that bit and use the stub.
              • Jul 2011
              • 6070
              Thanks!
              Yes this would work and I have use this brand in the past and had no issues with them
              However if you can Japan made terminals that are high temperature terminals would be the best but I have not found them very often
              • pulper111
                • Aug 2017
                • 39
                Just want to give a big thanks to everyone here! I received the quick disconnects in the link above, used the side cutters (helpful tip!) to close the gap, scraped off the burnt stuff (another helpful tip) and then put on some heat shrink. a couple pics here to show the finished product.
                wouldn't pass for professional but i've just used it and it works well.
                thanks!!!
                  • Jul 2011
                  • 6070
                  One thing I would recommend is after you have used for awhile take it back apart and see if there any issues with again
                  • pulper111
                    • Aug 2017
                    • 39
                    Good idea.
                    • electomech-fixer
                      First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                      by electomech-fixer
                      I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                      I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                      09-15-2025, 01:42 AM
                    • wnlewis
                      New wire for my RDE3340 Whirlpool electric range
                      by wnlewis
                      OK. I got the rocker switch figured out thanks to the good advice on this forum.
                      Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                      This is a Whirlpool RDE3340 electric range.
                      The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                      Where may I find parts...
                      01-08-2025, 11:21 PM
                    • emeskay
                      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                      by emeskay
                      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                      08-06-2024, 07:13 AM
                    • technicalspecialist
                      Vintage fan repair, copper wire question
                      by technicalspecialist
                      I currently have a customer's vintage fan on the work bench to repair.
                      It uses an induction motor with 4 poles. One of the poles is open.
                      I couldn't find the break so i cut off the original wire.
                      I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                      I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                      The enamelled copper...
                      03-16-2023, 12:54 PM
                    • edugimeno
                      Fancoil.controller with current issues
                      by edugimeno
                      Hi there! One friend called to say his fancoill (used for a main access cold Air courtain) controller caught fire, and asking if I could recover the half burnt board
                      He said the design was too bad as this thing was probably designed for hot water only, as the board was places right underneath the condenser radiators
                      I found some burnt traces and after a quick Google search for the board name (Pwr-05v-w) I could see an image of the original I was able to find where the original traces were going
                      The scheme seems simple, from what I understand mains gets into the while 3 lead...
                      07-26-2024, 01:02 AM
