PS4 WLOD troubleshooting
  • spleenharvester
    • Mar 2010
    • 908
    So between two monitors, various adapters and now my PS4 dying on me, I think it's fair to say I'm having a bad run of it
    My PS4 Slim F-chassis (CUH-2216A, board SAF-003) just went WLOD after plugging it into a monitor through a passive HDMI booster. I've tried safe mode, different cables, different screens, etc. Some monitors seem to get a signal but there's not actually any picture/backlight.
    I'm used to playing around with these in terms of basic repairs (I repaired about 1500~ at a facility I used to work at) but have never done board level repair on them, so please bear with me,
    I've checked the EMI filters (both for continuity to pins and lack of continuity across pins), diode continuity and for shorts in the circuit and can find no obvious issues (see pictures attached). I'm guessing in order to test voltages etc I have to put some kind of makeshift heatsink on the APU and fire the board up? Is that the best way to do this?
    If you have any guides that could be useful I'd really appreciate it too - I've watched a lot of youtube videos but can't seem to find any issues outside of the encoder IC.
    Many thanks
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 908
    Re: PS4 WLOD troubleshooting
    I've since taken some voltage readings (attached). Unfortunately after taking those readings and because I am still learning (read: absolutely hopeless at this) I shorted something and the board went dead - I've identified it as being the component circled in blue (attached), which I've removed and the system is now booting again and back to WLOD.
    Has anyone got any idea how I'd go about sourcing a replacement component?
    • reset1986
      • 308
      • italia
      set 200K and measure all pins hdmi connector, post
      there must be 5 gnd
      • spleenharvester
        • Mar 2010
        • 908
        there must be 5 gnd
        Thanks, I believe I've checked everything with the HDMI pins and can't seem to find any issue. I've ordered a new encoder IC and a part that I think will replace the one I shorted on the back.
        • vinceroger69
          • Mar 2012
          • 6714
          This facebook game console repair forum is well worth joining has some great ps4 info https://www.facebook.com/groups/console.repair.legion/
          • spleenharvester
            • Mar 2010
            • 908
            Cheers, I'll take a look if I have no luck! I've replaced the HDMI encoder today but can't test it yet because I'm still waiting for the other component... I'm worried I might have killed the chip as it took me about 10 minutes to get the damn thing in the right place but we'll see.
            • reset1986
              • 308
              • italia
              often on the ps4 the measurements are wrong, replace the encoder making sure to solder it, replace the ic in short, measure all the HDMI pins with 5GND- 1 N.C - 13 values
              • spleenharvester
                • Mar 2010
                • 908
                HDMI socket is all fine, 5GND and 13 connections with the IC removed from the board. I replaced the HDMI IC, no luck but I think I may have cooked it as I had a really rough time getting the chip soldered. I've ordered another one and am going to try again.
                • spleenharvester
                  • Mar 2010
                  • 908
                  Hi guys, another question on this before I change the IC again. Has anyone got any idea why I'd be getting 2.2V on the bottom-right pin of the SOT-23 component near the purple square if that leg is supposed to be NC?
                  I replaced this part with a 2.5V fixed-voltage LDO, and on these LDOs that bottom right pin is NC (no internal connection). Why would I be getting 2.2V on that pin if it was NC? After my first attempt to replace the HDMI IC + the SOT-23 at the same time, I was only getting 0.45V on that leg. I get 2.5V again at the top-right pin, as expected.
                  I'm just wondering if I should have replaced it with an adjustable voltage LDO (I used a fixed-voltage ADP151AUJZ-2.5-R7), because adjustable voltage LDOs use that NC pin for feedback to adjust the voltage. But I can't find where this would be driven from - I'm only getting continuity with the ceramic cap underneath it, I can't find anywhere else.
                  • spleenharvester
                    • Mar 2010
                    • 908
                    Just as a follow up to this, I've given up on this board - still WLOD after two IC replacements and I cannot for the life of me find anything wrong with the circuit. Going to flip it on ebay.
                    • reset1986
                      • 308
                      • italia
                      southbridge problem
                      • electroman5946
                        • Jul 2012
                        • 11
                        • US
                        theres a small diode that powers the encoder if its gets out of place any encoder you put in will not work. If one of the filters are damaged it will cause a no signal too. The filters btween the encoder and port can even be damaged with too much heat.
                        • PedroMa74111271
                          PS4 WLOD troubleshooting help.
                          by PedroMa74111271
                          Hello. I need some help with this topic if anyone can give me a hand. So I had a few PS4 already with WLOD, some I could fix(bad HDMI port, bad filters, and some bad HDMI encoders) but whenever o have a bad MN864729 HDMI encoder I'm always struggling. Don't know what I'm doing bad. Not sure if my solder skills just it's not good or if it's something else. Now I have this ps4 fat 1200 series(sac-001) with a wlod. I have checked the port and it's perfect, filters all good, diodes and all SMD components around HDMI encoder and port all seems to be normal. Just missing the encoder itself I already...
                          03-18-2025, 04:26 PM
                        • blues_spirit
                          practical courses for troubleshooting pc motherboards
                          by blues_spirit
                          Hello from France,
                          mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                          Do you think this is feasible for me? I...
                          12-18-2022, 12:56 PM
                        • Fide
                          PS5 WLOD EDM-030
                          by Fide
                          Hello guys,
                          I try to repair a PS5 with a WLOD.
                          At the beginning I should tell that I get a BLOD and after the UART reading and shorts on the caps near by the HDMI Encorder I change the IC. And after the change I get a WLOD. I also noticed that the filters was blown. I change them also.
                          The caps near by the HDMI Encorder are not shorted now. I also change the HDMI Port.
                          I get some readings in Diode Mode which doesnt look right to me.
                          1. HDMI Pin 18 i get 0.100V and Pin 19 OL
                          2. Diode on the back side 0,100V...
                          05-12-2025, 02:17 PM
                        • gcrezz
                          GV-N2060OC-6GD REV 2.0 GIGABYTE video card troubleshooting assistance needed.
                          by gcrezz
                          The issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the...
                          07-25-2024, 09:49 AM
                        • CrewmanRedShirt
                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                          by CrewmanRedShirt
                          Hello all,
                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                          07-13-2024, 11:02 AM
