Amstrad - dvr3000
  • fedebag
    • Dec 2017
    • 5
    • Italy
    Amstrad - dvr3000
    Hi guys, I've got a DVD Amstrad with power board Model DVR3000 - DVR POWER. DVD doesn't power on. I changed some capacitor fault but now I measure ashort circuit on a diode. Does anybody have Schematic about this power board?
    • Jul 2011
    • 6070
    Re: Amstrad - dvr3000
    Please show some pictures of the boards front and back so we what you are dealing with
      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
      by sam_sam_sam
      I was working on this CNC machine today found no keyboard functioning no control relay powering on
      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
      Found shorted diodes on main controller relays there are 3 of them that...
      01-07-2023, 05:43 PM
    • Destroyer-Br
      [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
      by Destroyer-Br
      I'm working on an Acer Nitro 5 unit with the following specs:
      • Motherboard: LA-J871P Rev: 1B
      • Model: Acer AN515-55-59MT
      • S/N: NHQ7JAL00403906A973400
      • SNID: 03902728734
      Initial Issue
      The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
      After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
      04-17-2025, 08:18 PM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
      by sam_sam_sam
      After all of...
      07-13-2024, 08:14 PM
