Opus BT-C3100 2.2 Problem
  • Jesse James
    • Sep 2018
    • 95
    Hello all. I am not sure if anyone is familiar with this lithium Ion charger. I have had discharging issues that turned out to be cracked solders for the discharge resistors. This is a 4 bay charger and tester with mah load test. The problem I am having is now bay 2 and 4 will not charge or discharge at all. It goes through all the steps as if it was working but my voltage never changes.
    I have tested resistors and diodes and also tried to compare a good working bay with the non working bay but am at a loss.
    Any help would be great
    • 31087
    Re: Opus BT-C3100 2.2 Problem
    complete pcb pictures would help.
    i didnt know the opus did a load test, i thought only the Litokala did that. - interesting to know.
    • CapLeaker
      Leaking Member
      • 8218
      each channel has it's own step down converter on the other side.
      https://www.youtube.com/watch?v=JJxrDgEFxMU
      • Jesse James
        • Sep 2018
        • 95
        Thanks for the help guys. As far as I can tell the step down converters are ok. I am thinking the gate voltages are wrong on my AO3400A mosfets (not sure) but I think the voltage varies on the amount of charge determined so it confuses me. All I know is at any setting 200ma-1000ma three of the four bays are only charging 30-40ma on my volt meter and when selecting discharge I am getting 0.
          • 31087
          fets are voltage not current driven,
          maybe there is a bad resistor somewhere - or the computer is running at the wrong clockspeed - fucking the PWM up.
          • Jesse James
            • Sep 2018
            • 95
            Ok thanks. If I do find anything I will post it here. Who knows maybe someone else will run into this someday.
            • Francesc V.
              Tempus fugit
              • Nov 2022
              • 231
              • Catalonia
              Hi:
              This is the summary I've been facing on this charger so far.
              Discharge problems:
              - Replace the six 5.1R SMD resistors from the affected slot. They use to burn after long use.
              Charging problems:
              - Check step down converter might be the issue.
              Wrong Voltage reading:
              - I am having a slot that reads about the half of the voltage when inserting the battery. I am investigating it.......but so far with no success. If somebody might have an idea, I would appreciate it.
              Regards,
              Francesc.
              • Petr0x
                Bosch 12V and 18V chargers modification
                by Petr0x
                Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                05-24-2024, 01:00 PM
              • reessi
                20v / 2A SMPS for a Battery Charger - Explanation of Blown Resistors Please..
                by reessi
                My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
                The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
                The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
                I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively...
                08-22-2024, 08:12 AM
              • motormayhem
                Lenovo T460 Only Charges on One Charger
                by motormayhem
                Laptop Question
                I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                05-12-2023, 01:46 PM
              • Thomasraud
                Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                by Thomasraud
                i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                QUOTED
                -It works on charger (without battery connected-only charger)
                -It works on battery (without charger connected-only battery)
                -& it also works when plugged in battery & charger, but it's not charging the battery
                //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                and..
                QUOTE
                The IC cannot maintain the input current level
                06-28-2022, 06:47 PM
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
