PLessey PV2413
  • llonen
    • Sep 2014
    • 495
    • hampshire
    PLessey PV2413
    I have had this come into the workshop from a local ham, does anyone have a specification for it and hopefully a manual, service or otherwise.
    • 31294
    Re: PLessey PV2413
    input voltage is unusual - aircraft intended?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Re: PLessey PV2413
      It's avionics all right. That is going to tough to find.
      • llonen
        • Sep 2014
        • 495
        • hampshire
        Re: PLessey PV2413
        intended for use with clansman series, these tend to run off 24 volts, I believe also used in aviation coms.
          • 31294
          Re: PLessey PV2413
          clansman?
          there is a guy who collects that stuff on here:
          http://www.transmission1.net/
          • llonen
            • Sep 2014
            • 495
            • hampshire
            Re: PLessey PV2413
            Thanks Stj, a search on the site reveals no information regarding PV2413 so a for technical information has been placed.
            • dicky96
              TV repair workshop advice please
              by dicky96
              Hi guys
              I put this under troubleshooting TVs rather than general electronics section as it is more related to TV repair. Mods, If I missposted this please move it.
              OK so I am moving from my little 7sq metre workshop into a larger workshop.
              I already put a deposit down on it and hope to move by the end of March once it is vacated by the current occupier.
              The new workshop is basically an open plan oblong room, 28sq metres. And it has aircon
              I have been thinking about how to lay out the new workshop. I will be undertaking a variety...
              03-14-2019, 07:53 AM
            • Ancient1
              Need to identify/find a Local buck/boost IC or comparable replacement. MI Streamer
              by Ancient1
              Hi
              Check out the photo : on the left is the blown IC ( bottom right) and on the right is same one : 6-pin AVBM .065 IC
              I can't find ANY mention of it online .
              The streamer is : Mi Box . Model MDZ-22-AB
              Thanks in advance...
              02-19-2023, 05:18 PM
            • Sileeth
              Remanufactured GTX 650Ti Resets and Driver problems.
              by Sileeth
              Hi!!! Nice Day/Night
              I bought a GTX 650Ti on Aliexpress, that could be the first problem... I think the card was built in a custom build version because it has 4 GB DDR5 of 2700 MHz memory (According to all programs except GPU-Z).
              With GPU-Z everything is fine except the value of the memory frequency, the software says that the memory frequency is 1350 MHz with reference to the original models of this graphic card.
              After opening the package, I disassembled the cooler and checked all the parts and the most important one, the GPU processor. Everything...
              05-26-2022, 07:12 AM
            • mon2
              Hunting down a virus in an office
              by mon2
              Hi. We have an office client who has been contacted by the local internet provider that one of the office Windows PCs is infected with a virus. The report has been confirmed. Apparently through a remote outside trigger, this virus is performing brute force attacks around the world from this local IP address at varying times. Aside from low level formatting each PC, what is the recommended approach for this case? Running F-prot (suggested by the internet supplier) has come up empty. We are planning to run hijack this. At this time, we do not know which PC is creating this issue. Internet provider...
              01-09-2025, 09:42 PM
            • cloo
              Panasonic ZT60 plasma tv with strange behavior and 8 blink code
              by cloo
              I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
              It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
              So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
              After doing a factory reset this problem was gone and the picture was back to...
              01-06-2025, 06:02 AM
