Fluke 289 bad supercapacitor replacement repair
    replied
    Re: Fluke 289 bad supercapacitor replacement repair
    maybe you could do the upgrade to a lithium rechargeable and a current limit resistor?
  • CapLeaker
    replied
    Did anyone’s replacement cap fail again? Charged up the batteries (takes roughly 2hrs)in my 289 and had to input date and time again. Ugh!
  • redwire
    replied
    I see- as an extra seal to protect against future leaks. I'm not sure what the acid is, as silicone sealant dissolves in sulfuric acid and puffs up in nitric and acetic acid. Larger supercaps can take a piss on a PC board. If the cap had a housing or was potted maybe.
    replied
    Originally posted by redwire
    The supercap electrolyte is acidic and it eventually corrodes through the case and causes a lot of damage. Putting RTV over that, uh just a mess for a few dollar part in an expensive multimeter.
    i didnt mean instead of replacement - i meant ON the replacement.
  • redwire
    replied
    For Fluke 289 jack-detect DS2, any top-emitting 0805 IR LED will work, just not too high to hit jack diffuser when you assemble everything.
    Original is mentioned as OSRAM SFH 325 FA-3/4-Z series, peaking at 980nm. One guy used 940nm Harvatek HT-170IRAJ works fine.
  • redwire
    replied
  • eccerr0r
    replied
    Is the electrolyte leak causing damage to other components?
    Anyway, probably the same answer as whether to use RTV on a regular electrolytic capacitor to prevent leaks, though a supercapacitor does not need to deal with ESR as much if it's just needed to maintain static RAM state.
    In other words, it leaks because it's under pressure...
    replied
    i wonder if putting RTV on the cap would contain it, or if the leak is under pressure??
  • Per Hansson
    replied
    Check for contamination inside the jacks for the cables.
    If memory serves me right there is an optical sensor there.
    So if there is dirt in the ampere jack it will cause this message...
  • fabry_85
    replied
    HELLO boys!
    I need your help. :'( :'( :'(
    I have the tester 289 that as I turn on gives me an "incorrectly connected cables."
    Could it be the super capacitor?
    it is damaged. the fluke is 289 and of the year 2008.
    I found on ebay a PANASONIC GOLDCAP KONDENSATOR Capacitor 0,22F 3,6V 10x5MM[/img].
    You can help me?
    Thank you.
  • Per Hansson
    replied
    Nice!
  • CapLeaker
    replied
    Nice! But you're supposed to post pictures to make us happy
    Beware you are about to see Fluke porn!
    I had to take the 289 apart again to make pictures. On a side note: The supercap held the memory for the entire time I had it apart again. So I am happy!
  • Per Hansson
    replied
  • CapLeaker
    replied
    Got the supercap today, it fits perfect, and the meters are back in business as they suppsed to be.
  • CapLeaker
    replied
    Keep in mind these meters have a minimum of 10 years warranty.
    So if anyone is not up to replacing them just send it in to Fluke to have them do it...
    https://www.fluke.com/en-gb/support/warranties
    There seems to be a mixed bag of results with this issue being fixed under warranty. However since this can be fixed fairly easily and way a faster than sending it into Fluke, I'll just repair it myself.
  • retiredcaps
    replied
    Originally posted by stj
    i seem to remember a long thread at eevblog about it.
    Yes. See
    https://www.eevblog.com/forum/testge...unt-coin-cell/
    replied
    didnt they fuck around over this?
  • Per Hansson
    replied
  • CapLeaker
    replied
    Unfortunately yes. Which sucks big time, because they aren't really a "cheap" DMM either. I am fortunate, that both caps were not leaking to the board yet making a mess. I suggest strongly to anyone that has a Fluke 287 / 289 to do this test and replace that cap before it is too late. Different revision boards, have different style of supercaps in it too. Also the 189 is affected, but not the 187 series.
    replied
    many meters have been fucked by that cap leaking!
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • the_rem
    Unknown transformer : how to find a good replacement part ?
    by the_rem
    Hello guys,
    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
    04-23-2025, 01:48 AM
  • ezenia
    PS4 controller left stick potentiometer replacement issue
    by ezenia
    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
    09-30-2023, 02:19 PM
  • quickname
    Cyberpower 1500AVR UPS repair
    by quickname
    I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
    Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
    I decided to verify that the batteries were...
    11-12-2023, 09:57 AM
  • boosti45
    Macbook pro logic board replacement parts quesion
    by boosti45
    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
    08-21-2024, 05:23 AM
