Fluke 289 bad supercapacitor replacement repair
    • 31283
    Re: Fluke 289 bad supercapacitor replacement repair
    maybe you could do the upgrade to a lithium rechargeable and a current limit resistor?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8351
      wouldn't that charge the lithium permanently, even with the current limiter resistor... unless the resistance is very high? Educate me!
        • 31283
        i think it is very high.
        old and new boards.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8351
          Interesting indeed… did anyone convert their 289 yet?
            • 31283
            i only know one 287 owner - he's selling or already sold it.
            it's considered a bit shit compared to a unitrend 171/181 or even a fluke 80 series
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8351
              I've got a Uni-T meter... not so thrilled with it.
                • 31283
                they go up in quality with the price
                i have a potentially usefull pdf for you
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8351
                  That handbook is very interesting and thank you for it. Problem is here in Canada you can't get any of these lithium batteries. Years ago, our Government banned lithium batteries from commercial flights. So basically, if the package isn't shipped a special way (which is ridiculous in price) you plain just can't buy it. Go to Digikey Canada and see for yourself. Some outfits don't sell you certain parts, if you ship it to a Canadian address. I could order from a selected supplier in the US, but again shipping is a killer. Been there and done that. Only way to get a lithium cell for me is to go to Ali and order there, it has a mediocre success rate. I had a few shipments that never arrived.
                    • 31283
                    i think that may be wrong because these can be shipped without any charge in them - although your government isnt exactly intelligent right now!
                    the chinese did have a workaround for the flight-ban,
                    equipment with internal batteries were exempt.
                    so the ali sellers were shipping batteries inside obsolete tv remotes!
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8351
                      Same thing here. Equipment with internal lithium batteries are exempted. Its just a real dumb law that doesn't make any sense again.
                      • AleXis6
                        • Feb 2021
                        • 69
                        • Belarus
                        #31
                        Could you help me please:
                        how long Fluke 289 should keep Date without AA bat?
                        and which another brand of supercapacitors can be used?
                        or could I put a special same size battery instead of supercap?
                        thank You
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8351
                          If you take the battery out, wait a minute and put the battery back in and the 289 lost time and date, good chance that the supercap is leaking physically. A new supercap held the time and date for 3 hrs no problem. As a size requirment: Everything goes as long as it can fit. The only thing to watch for is the rated voltage. For some reason most 3.3V supercaps I came across were SMD, but I surely would not use a 5V supercap in there. Swapping in a battery depends on the battery chemistry you want to use and then have to mod the circuit somehow. I see that my original solution isn't anymore available. At least not here.
                          • AleXis6
                            • Feb 2021
                            • 69
                            • Belarus
                            #33
                            My Fluke forgets the Date after 4-6 hrs (during I am charging 6xEneloops due to I have just 4 slots for charging AA) but it keeps Date at least for a few minutes if I just change old AA for new ones. I have not checked the exact time.
                            Are you suggesting opening Fluke for revision of supercapacitor's leakage?
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8351
                              do a test and take them batteries out for 15min, 30min, 45min and an hour... see what happens... My 289 is old. The new 289 doesn't have a supercap anymore. They changed them to a battery. I charge my 6 eneloops in one swat (bigger capacity charger).
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8351
                                I charged my batteries for one hour and I've lost the memory. Set time and date appeared again. So my supercap that I replaced in 2018 went bad again.
                                I did look at the newer 289's and they have a battery with an SMD resistor marking 01B (1k ohm) in series with the positive side of the battery. I may take my supercap out, add a 1k ohm resistor and put a small 3V coin cell battery in. That should fix that.
                                That image I borrowed is from Terry01 from eevblog. Thanks man! It saved me running to work and taking theirs apart!
                                • AleXis6
                                  • Feb 2021
                                  • 69
                                  • Belarus
                                  #36
                                  I measured the voltage it is about 0,9V
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8351
                                    It's done for. Well... I guess I am sitting in the same boat again and looked around to see what is suitable right now for me and didn't find anything in the supercap section as an available drop in to buy. I'll keep looking...
                                    • AleXis6
                                      • Feb 2021
                                      • 69
                                      • Belarus
                                      #38
                                      and didn't find anything in the supercap ..
                                      the same, just chineese version.
                                      Date has been lost even after 5 min
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8351
                                        Sooo... I've got the idea to call Fluke Canada. Here is how the limited warranty goes with Fluke: The limited warranty is good for about 10 years! After the 10 years has passed, you need the proof of purchase. Guess what? Mine is 10 years and 3 months old! They quoted me CAD $370 for a repair. REALLY? 370 bucks for a damn $2 supercap? I guess I fix it myself again.
                                        As for the supercap to rechargeable battery mod. It's not going to work for me economically. Lithium batteries are not allowed to be transported in planes here in Canada and can only go via ground. As of this all Canadian suppliers like digikey, mouser and newark put shipping restrictions. So even if I get a battery from the states through allied, gonna cost me like $80 shipping or more (I tried that already before).
                                        Meanwhile I did come up with another SMD supercap, but it's like 10.5mm diameter. So I guess something has to be modded. I guess I have to open mine up again and see what can be done this time around.
                                        • AleXis6
                                          • Feb 2021
                                          • 69
                                          • Belarus
                                          #40
                                          10.5mm diameter.
                                          I think similar due to enough space around.
                                          which supercapacitor you used last time ?
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • the_rem
                                            Unknown transformer : how to find a good replacement part ?
                                            by the_rem
                                            Hello guys,
                                            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                            04-23-2025, 01:48 AM
                                          • ezenia
                                            PS4 controller left stick potentiometer replacement issue
                                            by ezenia
                                            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                            09-30-2023, 02:19 PM
                                          • quickname
                                            Cyberpower 1500AVR UPS repair
                                            by quickname
                                            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                            I decided to verify that the batteries were...
                                            11-12-2023, 09:57 AM
                                          • boosti45
                                            Macbook pro logic board replacement parts quesion
                                            by boosti45
                                            i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                            08-21-2024, 05:23 AM
