Benchtop Pro MD95 Dremel Burnt resistor now works at Full speed only
  • DJ_MIX
    • May 2005
    • 118
    Guys need your help.
    I believe it got wet a bit which then cause it to only run at full speed, no longer can adjust speed.
    Opened up and notice burn near resistor. I guess I need new resistor but what value? I did not test any further, I guess I can remove resistor and check.
    Let me know what you think. Also what is ntc 60?
  • R_J
    • 9514
    Re: Benchtop Pro MD95 Dremel Burnt resistor now works at Full speed only
    I would guess the triac is shorted, looks like that resistors been running hot for a while and it may still be ok. Remove it and check its value, look and see if there are any values still visible on the resistor
    • DJ_MIX
      • May 2005
      • 118
      Remove it but didn't see any values on the resistor. It did measure 5.2 ohms with multi meter. Which one would be the triac?
      • petehall347
        • Jan 2015
        • 4422
        • United Kingdom
        yes the triac is suspect . or the pot is damaged .. maybe still damp .
        • petehall347
          • Jan 2015
          • 4422
          • United Kingdom
          triac is the one with 3 legs
          • DJ_MIX
            • May 2005
            • 118
            Thanks Guys, the trace near the resistor was lifting so I glued it back. Once I but it back I will retest.
            • R_J
              • 9514
              Remove the old solder and resolder the resistor, if the trace is bad just replace it with a piece of wire, Provide the number off the triac (3 leg part) if there is one.
              • redwire
                • 3900
                It looks like the speed controller was overloaded, cooked the resistor and triac. The NTC was useless, it was supposed to limit power.
                Drew a schematic but not sure what the cooked R3 resistor's value is.
                The circuit did not make sense unless there is a diac or something underneath the hot glue blob.
                If you can give the resistor ohms and triac part number, I will update the sch.
                • DJ_MIX
                  • May 2005
                  • 118
                  WOW, thanks
                  The resistor is mwntion above at 5.2 ohms
                  triac is Z0409MF A149
                  Sorry had no time to mess with unit.
                  • R_J
                    • 9514
                    It's very likely the triac shorted, that would cause the motor to run full speed
                    • DJ_MIX
                      • May 2005
                      • 118
                      I will remove and try to test it.
                      • DJ_MIX
                        • May 2005
                        • 118
                        Problem solved, appears it was the Pot, I cleaned it and now have variable speeds..
                          • Jul 2011
                          • 6018
                          If you can find a new pot I would recommend replacing it
                          It might do the same thing again
                          • CG2
                            LED uplighter dimmer burnt resistor
                            by CG2
                            I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
                            02-14-2024, 09:23 AM
                          • trickartt
                            Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
                            by trickartt
                            Hello Badcaps!
                            I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
                            This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
                            05-04-2024, 12:07 PM
                          • sparcktikus
                            Ersa Rds 80 soldering station burnt resistor
                            by sparcktikus
                            Hi
                            I have an Ersa rds 80 soldering station which has developed a fault and just showing err on display
                            I have found a burnt resistor on pcb can anyone help me identify this resistor if you have a circuit diagram or similar unit
                            The printed circuit board markings are rd80 ver 2.0 and the resistor in question is R6
                            Many thanks...
                            04-04-2023, 04:29 AM
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                          • mikey5791
                            Need help to replace burned resistor in 350w atx psu
                            by mikey5791
                            Hi to all forum members,
                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                            12-26-2024, 04:55 AM
