Cisco Catalyst 3750 fixed
+ More Options
Posts
  • piernov
    • Jan 2016
    • 4437
    • France
    This wasn't an easy repair so I thought it would be interesting to share it, also it's not quite common to see this kind of stuff being worked on.
    So here we have a Cisco Catalyst 3750 with a no power issue.
    The PSU (Phihong PSM200-120(MC)) was obviously not giving any voltage on its 12V line.
    After a bit of basic troubleshooting, the issue was found to be on the primary side: the VCC (pin 13) of the SMPS controller (ML4824) was at around 5V when it should have been around 13.5V. As they often go bad together, I checked the switching MOSFETs, and they were partially shorted. I replaced both the controller and the 2 MOSFETs (IRFP460, good habits to replace all of them in one go if you don't want to see fireworks) and the PSU is good to go. 12V is back and PGOOD signal is 4.6V.
    But that wasn't enough to resurrect it: the motherboard would still not give any sign of life. Checked the voltage on the coils on the left side, 3.3V and 5V were present, but no 1.5V, 1.8V and 2.5V (thanks Cisco for labelling those). After some probing, I found that 1.5V and 2.5V controller (ISL6558 on the back side) weren't even powered, but the 1.8V had only around 1V on its VCC when it should have been 5V.
    Traced the line back to the 0 ohm resistor near the PIC, itself near the power connector. After removing that resistor, one side had 0V (the one going to the ISL), the other had 5.4V. The path to the ISL wasn't shorted, so I injected 5V and the switch turned on. This line sinked in 60mA.
    Ok, so there is an issue on the supply side. Sure enough, the second transistor above the PIC had 12V on its collector, 6V on its base, but the emitter was 1V when the resistor was connected, and 5.4V when it wasn't.
    After replacing it with whatever NPN I had lying around (C6144, see the standing transistor near the power connector on the picture), the switch is back in working order.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Cisco Catalyst 3750 fixed
    Today I fixed a 3524 XL PSU: burnt fuse and shorted 2x IRF840. PSU works but I don't have uplink. Going to take a look at the console later.
    I'm going to replace a dead LXT970AHC ethernet tranceiver by a LXT970AQC on a 2600 series too. Expensive, a pack of 2 of those is the same price as the used switch in good conditions itself… But I'm not going to throw it out anyway so let's get it fixed.
    • piernov
      • Jan 2016
      • 4437
      • France
      Unfortunately the 3524XL has multiple bad SRAM (IS63LV1024-12J). They're available only on eBay from a Chinese seller and very expensive…
      • piernov
        • Jan 2016
        • 4437
        • France
        2600 fixed with the new Ethernet tranceiver.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Good job and thanks for the info , very interesting read!!
          • madan1
            Cisco catalyst 2960c POE
            by madan1
            Hello everyone.
            Got a catalyst 2960 from the usual scrapyard - ebay.
            It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
            Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
            Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
            The switch fails to boot due to the following POST error:...
            12-19-2024, 09:34 AM
          • howardc64
            Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
            by howardc64
            TV was fixed just after removing Samsung's rear snap cover.
            This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
            Maybe PSU->backlight connector didn't have a good contact?...
            07-23-2025, 12:34 AM
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
          • howardc64
            LG 55UN7000PUA fixed with just dis/reassembly
            by howardc64
            TV runs, backlight on, have sound and no image (dark grey/blue/black LCD)
            Disconnected right (looking from rear of TV) tcon-buffer board cable, LCD left half displays.
            No shorts on right buffer board.
            Started masking tcon-buffer board signals... (connection #1 in main board pic) about 20+ pins from top of connector... LCD fully displays with some anomalies.
            Gradually reduced # of masking signals... eventually down to 1. Removed that... LCD works perfectly.
            No obvious damage on right buffer board 3x COF to the panel like another 43" LG fixed ( link ) with...
            09-19-2024, 11:16 PM
          • madan1
            cisco poe switch PSU issue
            by madan1
            Hello everyone.
            I'm troubleshooting a cisco switch, which seems to have an issue with the PSU.
            The psu has the following power rails - +12v, -53.5V and +3.3V
            When connected to power, the +12 and -53.5 seem to work fine, but the +3.3 starts at ~3v and then goes down to ~0 (I guess this is the cap discharging). This happens both when the cable is connected and not to the switch board.
            Any ideas what might be causing this behavior?
            04-23-2024, 01:58 PM
