Is it possible to replace a Blu Ray control Board on ps4 ?
Repair PS4 CE-35888-2 error code WITH or WITHOUT the original BD-ROM Logic Board - play game discs!
https://www.youtube.com/watch?v=EoA-5q35QIw
It's held across the APU/NOR/SYSCON chips on the motherboard and on the BD-ROM Daughterboard. On the BD-ROM Daughterboard the chip you're interested in is the Renesas chip. If you have a faulty drive board then you can purchase the identical revision board from AliExpress and transplant the Renesas chip across to get it working again. I've done this before and it's worked perfectly. It's not the easiest swap as the chip has lots of legs at very fine pitch but if you're good with an air wand then it's a perfectly reasonable repair.
http://www.pcrepair-stockport.co.uk/...eplacementent/
PS4 repair CE-35888-2 Error Code drive controller cards BDP-010 & BDP-020 model CUH-1001A
https://www.youtube.com/watch?v=pPRvG6oRV1E
Tengo una pregunta? Mira las fotos, Is that Renesas chip IC damaged? because change it is mucho trabajo.
