Vorwerk Thermomix TM21, problem with temperature selection control
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    Thermomix is a popular kitchen "robot" in Europe. There're a few models (TM21, TM31, TM5). They're very expensive machines, and they cannot be bought at a normal home appliances shop. I'm trying to fix an issue with a TM21 unit.
    Main problem was that temperature selection wheel was unstable. It's a 22KΩ linear potentiometer that lost contact easily, specially with appliance vibration while working. It's a Piher PC-16 bushless version.
    I opened the pontentiometer and cleaned it. Now it's stable but the machine keeps doing something incorrectly (it did the same before). The temperature selection wheel has 10 positions (0, 40, 50, 60, 70, 80, 90, 100, Varoma). At 0 position it doesn't heat, and from 40 onwards it has to activate heater and the orange/red LEDs at temperature wheel side.
    Well, the problem is that this one only activates heater and LEDs from position 70 onwards. On 40 and 50 it does nothing, like still at zero position.
    I have another unit of TM21 to compare, and I'm tired of testing things (swapped potentiometers, tested voltage drop at potentiometer, etc.), always the same problem and no significant phisical differences between both boards. Finally I've noticed something curious: these units carry a 1Kbit EEPROM ST M93C46-BN6T. The controller is a NEC µPD78043FGF-060, it only has ROM, nothing programmable here. These appliances have no user data to store. Nothing can be programmed, recorded or customized. It wakes up the same way every time you turn it on. Why does it need an EEPROM?
    I've tried to answer myself: I've put EEPROM IC from working unit to the other and the problem is gone!
    Theories: since potentiometers used to select Temperature and Speed have some tolerance, perhaps there's some factory mode where the top and bottom voltage readings from the potentiometers are stored in the EEPROM.
    I'm considering to get an EEPROM programmer and clone the data from the working unit into the trouble unit. If there's a factory calibration mode, I don't know how to enter it. I see no hidden buttons or open bridges. If it exists, it must be some funny combination of button presses.
    • Jul 2011
    • 6058
    Re: Vorwerk Thermomix TM21, problem with temperature selection control
    It maybe that the EEPROM chip is program out side the unit
    Where I work we have two saws that there controller board is
    that way there is no programming port
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • SidneyCanadas
      93C46 and 93C56 EEPROM
      by SidneyCanadas
      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
      06-14-2023, 01:16 PM
      Fintek F71868A Super I/O and Hardware Monitor Datasheet
      The F71868A which is the featured IO chip for PC system is equipped with one IEEE 1284
      Parallel Port, two UART Ports, one 80 port (multi with COM2), Hardware Keyboard Controller, and SIR. The F71868A integrates with hardware monitor, 9 sets of voltage sensor, 3 sets of creative auto-controlling fans and 3 temperature sensor pins for the accurate dual current type temperature measurement for CPU thermal diode or external transistors 2N3906. Others, the F71868A supports newest AMD TSI and Intel PECI 3.0 interfaces and INTEL Ibex...
      10-23-2024, 02:26 AM
    • dmccul2698
      Pioneer DEX-P99rs "No EEProm " diagnostic code.
      by dmccul2698
      Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
      1). Understand the schematic and check the connections between the EEProm and DSP
      2). Check the functionality of the EEProm
      I don't know if this is the unit's problem but it's a place to start.
      I have little to no electronic experience...
      04-08-2024, 05:32 PM
    • CapLeaker
      AcuRite 5 in 1 temperature sensor replacement repair
      by CapLeaker
      Got a new victim:
      AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
      A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
      B: stuck at some temperature and maybe updating once in 12 hrs or so.
      Easy solution is to go to AcuRite website and purchase the sensor. Right?...
      04-15-2025, 01:32 PM
