iRobot Roomba 620 repair, side brush not spinning, water damage
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    I was about to refuse this repair, because it's an appliance that I don't know at all, but the customer insisted and, after all, he said a new unit costs 350€, so it's something worth working for a few hours.
    Side brush doesn't spin and customer already changed motor, to no avail.
    I disassemble the device following a Youtube video. When reaching main PCB I see two spots with mild liquid damage. The most interesting spot is near the H-Bridge that controls side brush motor (2 pairs of SS8050 / SS8550 transistors and 4 diodes). Q74 is shorted and no other shorts detected. I replace this SS8550 and try again, still doesn't work. Check again the other 3 transistors and Q74's complementary, Q64, isn't shorted but it has a lower resistance reading than its neighbor. I replace this SS8050 and now it's fixed!
    It seems that some water drop made its way to the PCB and caused a short circuit, damaging these two transistors. The PCB is fully protected with white paint and no traces were apparently damaged.
    All motors are controlled with H-Bridges, 2SD882 / 2SB772 pairs for wheels and main brush, and SS8050 / SS8550 pairs for side brush.
    20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
    I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
    At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
    Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
    04-09-2023, 08:04 PM
  • Ugur87
    MacBook Air M4 A3240 Brand New Water Damage no Image
    by Ugur87
    I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
    08-28-2025, 01:09 PM
  • inspirim
    iRobot Roomba 620 i need dump bios
    by inspirim
    Seeking dump 25Q16
    thank you all
    10-20-2022, 11:12 AM
  • edugimeno
    Stagg sms12p audio amp has water damage
    by edugimeno
    Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
    I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
    There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
    There is only one signal wire connecting the first boards...
    05-24-2025, 06:00 AM
  • RetroComputingGrotto
    Water Damaged Toshiba 48L1435DB
    by RetroComputingGrotto
    I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
    The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
    10-07-2024, 08:23 AM
