Help with Motor Control Board - ProForm treadmill
    Re: Help with Motor Control Board
    There is Zener diode connected to VDD pin and Ground of that MOSFET driver IC, check to see what DC Voltage you get, again this hot circuit so do not touch anything with your hands or body.
      No that is maybe a little shadowing but more of one of the solder joints to that resistor. I'll reassemble the board again and test that Zener.
        Ok the zener and that mossfet both tested at 12.1VDC
          I also just tested the diodes D9 D10 D14 D15 D16 which all look like they are identical. I get 0 reading in all but D10 which gives me an .5 ohm reading and it has continuity where the others don't. Does that sound right?
          It looks like D10 connect to DZ1 and then to the relay.
            So we do have power to run this MOSFET driver IC.
            D10: There may be another component connected in parallel with D10, you need to lift one leg or remove it off the board for proper test. Pictures and location on the board?
              Here is the picture, located on the bottom corner near where I had the bad zeners.
              This is the bottom of the board.
                Did you miss word/words out of this
                  By looking at the board the only thing it is connected to is the zener in DZ1 and the one leg of the relay switch.
                    No that was in response to your question possible shadowing or burn mark on the orange resistor.
                      Here is another picture of where D10 goes. Not that great but I don't have color printer.
                        It looks like generic diode 1N4XXX series, remove and test it off the board.
                          I removed D10 and it still shows continuity and reads .5 ohms.
                            Looks like it's 1n4148 diode. I hooked it up to a 9v battery and got nothing so I guess it's shorted.
                              On my way to store to get that diode and the 2 large wound resistors.
                                Ok I just got the 2 large resistors, got 10w 1000ohm ceramic. Maybe not large enough cause they measure .831 and the original measure 1.442 in diode mode. I also replaced D10 and now it measures .609 but if I reverse the leads it measures 1.031. Motor still won't turn on.
                                  So the old two black resistors are both 1000 Ohms for sure?
                                  "Ok I just got the 2 large resistors, got 10w 1000ohm ceramic. Maybe not large enough cause they measure .831 and the original measure 1.442 in diode mode" You are measuring the resistors in Diode mode?
                                    Selldoor in post #145 said it was so that's what I got. However I have a new problem now. I was testing to make sure I still had the voltage from that small 8 pin mosfet and I must have shorted it or something because all of a sudden the treadmill motor just started at full speed. Now it won't shut off except by turning power off, even when pulling out the safety switch.
                                      The Gate drive stuck high so the MOSFET is fully on when you shorted out the Gate drive IC TC1410, do not run it or you burn out the motor.
                                      So it proves that the drive circuit is OK, you just do not have the drive signal to drive the MOSFET.
                                        So do I need to replace TC1410 now?
                                          You can remove it and see if the motor will still run at full speed, just do the quick test, if it does then the MOSFET is damaged.
