Help with TD1232 PBX (telephone switchboard) power supply
  • gervabit
    • Aug 2025
    • argentina
    Good morning — I need help finding the value of a resistor (R408) on a power-supply board.
    I haven’t been able to find the service manual for this particular board. The resistor is connected in series between pins 12/11 and 10/9 of an STK73908 IC (in its typical circuit, there is no resistor).
    • 31304
    0.33ohms
    page4
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
      by sam_sam_sam
      03-31-2024, 02:12 PM
    • gica69
      Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
      by gica69
      I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
      Resistor shows orange range silver gold and green lines.
      Thanks in adv...
      07-21-2025, 09:49 PM
    • Safrilhg
      Look for the resistor value in the BenQ G922HDAL monitor's power supply
      by Safrilhg
      Hello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
      In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
      How to determine the appropriate SMD resistor value for this condition? Thank You...
      11-06-2023, 12:43 PM
