Seven Leagues Slot Machine stop button issues
looks like it doesnt use a battery,
there is a mystery chip on it called 85c64-20 that sounds like a ram but i cant find a datasheet.
maybe it's non-volatile
there is also a27128 rom chip above it you may want to backup if you have a programmer.
thats only 16k so there is probably more boards hidden away.
Update! FIXED!
I decided to remove the button board to check the backside of the connector. The trace was completely broken! I soldered a piece of wire in place of it and it's working perfectly now!
Thank you guys for your help 😁
Now I need to figure out why the belly light flicker on and off repeatedly.Leave a comment:
ignore the door for now,
get to the main logic board and see if it has corrosion from a leaked backup battery!
all gambling machines have battery-backed book-keeping memory for legal reasons.
the batteries leak.
as for the door switch - that puts the machine in service mode when you open the door,
some machines it gives you credits and lets you step the reels & stuff.Leave a comment:
the batteries leak.
the batteries leak.
The difference between door open and closed is a bit weird.
It might be a damaged/pinched ribbon cable in the hinge, poor connection in the IDC connector. Take a look if it's mangled anywhere and gently reseat the connectors.
Or it's cross-talk of some kind between two switch lines. That sorta implies an IC is pooched. Some switches get zapped hard with static electricity and damage the IC. Voltage readings at the switches would help.
I'd gamble... power off and try an ohmmeter reading from the pushbutton and all the way to the LED "switch indicator", maybe they connect and you can find a place with continuity, to check the ribbon cables etc. See if you can beep out some path from the door CN4,5,6 up to the main board.
The slotted-optical switches, I can see two. Ambient light, dirt dust, or age if the LED fades can affect them- but it doesn't sound like you have a false door-open signal. IR goes through electrician's black tape, not sure how good a q-tip is lol.Leave a comment:
OMG massive nails hammered through the wood, look for anything near nail holes that hit the board and damaged them, or wires/cables etc.
The top wood panel had one nail left in place. OUCH.
Also a big rust puddle under the power transformer on the bottom right? not sure what liquid got in there.
The switch inputs look like they go to the LED indicators on the board, and then the opto-isolators. I would take voltage readings on the switches, see if they look weak or OK.
I noticed last night that with the door open button 3 does not work/register on the diagnostic board. If I close the door it then works. Odd. There is an optical sensor mounted on the door, but I tried making it see a qtip and subsequently pressing button 3 and with door open and the button did not work, so I don't think that has anything to do with it.
Attached are photos of how the buttons are hooked up. Also there is a photo of the optical sensor on the door.
The switch inputs look like they go to the LED indicators on the board, and then the opto-isolators. I would take voltage readings on the switches, see if they look weak or OK.Last edited by redwire; 02-13-2025, 11:49 AM.Leave a comment:
get the plastic cover off the main board so we can see if it has any kind of battery on it for backing up the book-keeping
I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
The issue now is the Stop buttons are intermittently working. So far button 1 (left) has not worked at all to stop the first reel. Button 2 appears to work consistently every time. Button 3 sometimes works and sometimes doesn't. When I watch the diagnostic lights I can see that when pressing 1 it's not registering, and when 3 DOES work it DOES register on the diagnostic board, but when it doesn't work it doesn't register. Button 2 appears registers when pressed.
I swapped the wires between them to see if it was the buttons themselves. 1 and 3 will both work perfectly fine if they are plugged into the 2nd plug. This rules out the buttons as the issue.
My buttons do not have optical sensors like some other machines, but rather they are just push buttons with two wires rubbing straight to the board. I don't know if it's an issue with the C10 capacitor not being there, but I highly doubt it because a broken connection would always be broken, not intermittent. It seems like a logic issue of some sort.
I will post more pictures later to help show the setup.Last edited by x_orange90_x; 02-12-2025, 10:50 AM.Tags: None
This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-12-2024, 03:28 PM
by CG2OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Fam787I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...5 Photos12-27-2024, 05:19 PM -
by MullySculderHey folks, I'm working a 2018 13" Macbook Pro that I can't get to install an OS on.
This was given to me by a friend who told me I could have it, if I fixed it.
I've noticed a couple of dents on the laptop case and the touch bar doesn't have any activity lights when first turning on. When I boot up the machine, it gives a folder with a question mark. When I do eventually get to internet recovery with High Sierra, I can go to Disk Utility but I'll get errors when I try to erase the 512GB SSD. First Aid comes back with no issues. But if you linger too long on anything,...07-10-2024, 02:17 AM - Loading...
