Identifying single cell Li-ion charger IC
  • martonmiklos
    • Jun 2021
    • 20
    • Hungary
    I am trying to repair an Autec A08 remote which does not turn off and depleting the battery
    I spotted a burn mark on the li-ion charger IC what I removed, and after the removal the power ON LED is no longer continously on, however it does not turn on at all.
    I traced the enable signal of the VBA - 3V3 DCDC LM3674 converter and it is wired to the charger IC through some passive network.
    Likely to disable the power for the MCU/RF part during charging in the bay.
    After investigating the IC further I got to the following:
    The markings were barely visible as the board was coated, my best readout from the IC was:
    AAAC
    1702
    I have attached an photo from the IC itself but it is quite useless in quality.
    The board itself is made from mostly western semiconductors (Atmega128A, MSP430, LM3674).
    Does anyone has a good tip about what type of IC could it be?
  • martonmiklos
    • Jun 2021
    • 20
    • Hungary
    For the shake of posterity: finally figured out: MCP73833-FCI/MF
    • flat-earther
      ASUS X54H laptop thinks it's always charging even with charger unplugged
      by flat-earther
      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
      Windows also shows ''Plugged in'' when charger is not connected.
      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
      If I let battery run out and say it has 3% Windows will...
      06-24-2025, 09:32 AM
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
    • Johndill
      Dell Inspiron 7567 LA-D993P odd charger issue
      by Johndill
      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
      Here are the tested scenarios:
      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
      2. With the laptop off, plug in charger (LED says on) & the front charging...
      11-16-2022, 10:55 PM
    • Petr0x
      Bosch 12V and 18V chargers modification
      by Petr0x
      Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
      You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
      Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
      05-24-2024, 01:00 PM
    • exerion5000
      DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
      by exerion5000
      Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
      below normal, as if it were operating in an extreme energy...
      10-15-2023, 02:12 PM
