Mighty Dry Herb Vaporisor
  • MarkRocket
    • Jan 2020
    • 17
    • United Kingdom
    I have got a faulty Mighty Dry Herb Vaporisor, it fully powers on and works ok, but does not charge the batteries
    I have found a shorted components next to the power in jack, it has the logo on it from General Semi, and the marking BT 06A, but I can't ID what the actual part number/model number is to be able to get a replacement
    Can any help ID this component please
    • 30917
    i think it's a bi-directional Transil surge protection device.
    probably 6v rated - is it a 5v input on that?
    • MarkRocket
      • Jan 2020
      • 17
      • United Kingdom
      The rating of the device is 12V at 2A, I have been doing some research of my own, I think it may be a SMBJ18CA 18V 600W TVS Diode
        • 30917
        that makes sense for a 12v rail.
        • MarkRocket
          • Jan 2020
          • 17
          • United Kingdom
          Thanks, I have ordered a couple SMBJ18CA, I will let you know if it works
            • 30917
            it should work without it
            • redwire
              • 3900
              Power input TVS is shorted... yet it powers on? Makes no sense. Next full moon is Nov. 15 Beaver Moon so that isn't causing it lol.
              I would check the green fuse next to it. There should be one for the battery. But which connector is that?
              • MarkRocket
                • Jan 2020
                • 17
                • United Kingdom
                Yes, it does power on but does not charge, there are two 18650 type batteries in this device, both plug in via a two pin connector (the white ones behind the barrel jack, also both the batteries have a two pin connector for I assume temperature that is separate from the power one these are the smaller white connector above the barrel jack
                • MarkRocket
                  • Jan 2020
                  • 17
                  • United Kingdom
                  Well good news, thank you for all the help, the replacement component (SMBJ18CA) has been fitted, no shorts detected, internal fuse ok and unit is now charging again!!
                  • carrzkiss
                    Cyberpower cps1500avr not charging batteries
                    by carrzkiss
                    Hello, all.
                    Cyberpower Battery Backup Unit.
                    I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                    When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                    In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                    Checking the voltage, it was down to 22v.
                    I quickly removed everything...
                    06-15-2024, 02:10 PM
                  • harp
                    Diodes marking (ON semi) 211 and 5DB
                    by harp
                    I have strange diodes, and want to see some datasheet...
                    First is smd on semi mark 211, with voltage drop of 0.080v at 27 deg.C?
                    Second is tht mark 5DB, but cannot measure voltage drop, strange shape and black painted (isolated) upper half of legs...
                    Any idea?...
                    09-17-2023, 03:00 PM
                  • howardc64
                    Where do repair shops buy MB replacement batteries?
                    by howardc64
                    Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                    Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                    BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                    07-25-2024, 10:42 AM
                  • Astonished
                    Fixing the Charge Circuit of the Batteries of the DC Motor
                    by Astonished
                    Hi friends of electronics
                    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                    Please help me fix this circuit.
                    (the datasheet of the IC: https://pdf.datasheet.live/28...
                    01-28-2025, 06:24 AM
                  • davidebaldini
                    UPS ruins batteries every three months
                    by davidebaldini
                    Problem description:
                    My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
                    UPS model:
                    The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
                    10-02-2019, 06:19 AM
