I'm thinking about modding a old ps3 PSU:APS226
  • tronik25
    • Dec 2013
    • 15
    http://www.psdevwiki.com/ps3/Power_S...U_compatiblity
    I got a cecha01 model ps3 with a aps226.From what I read this power supply gets very hot.I thought maybe I could try to see if their is something I could do to make it run cooler.Not talking about just throwing a fan on it.I'm not experienced with PSUs but i'm guessing the mosfets are the major main components that generate the heat.
    Am I right?Here is what is printed on most I was looking at in the psu.
    Qty.2 of
    F m g25
    fqpf
    13n50c
    qty.1 of
    stth15r06fp
    GK1H9 can't read but(V6?)
    CHN 620
    qty.2 of
    21n50c3
    GCW626
    qt.2 of
    06CN10N
    6AB622
    qty.1
    N 6G
    FCH10A15
    Sorry I don't have more details on them,will add more info as I go through the components.
    Atm i'm just wondering if its possible to get this psu running cooler.Some in the vid game forums said to upgrade to a aps231 to others asking about compatible PSUs for their cecha01 ps3.
    But many had problems,console would shut/kickoff when it was getting pushed to its max using the aps 231.
    I don't mind if I spend a decent amount modding this psu.Would rather have new parts anyway.Every psu is used for ps3s(98% of the time).
  • Agent24
    I see dead caps
    • Oct 2007
    • 5037
    • New Zealand
    Re: I'm thinking about modding a old ps3 PSU:APS226
    I may be wrong but you may be able to replace the switching MOSFETs with newer models that have a lower on resistance, which should make it a bit more efficient.
    However even if that did work I don't know if the difference would be great enough to make much of a heat reduction.
    -David VanHorn
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      In my experience, the APS226 and APS227 are good. It's the ZSSR5391A you want to avoid. APS226 is made by Sony itself, while the ZSSR5391A is made by Nichicon. I have over ten faulty ZSSR5391A now, all with the same or similar fault - their 12V rail shorts to ground or refuses to kick ON, and only the 5V standby works.
      Not much you can really do IMO other than... well, adding a fan in there. They already do use very high-spec MOSFETs in there. The problem is these PSUs are too crammed and they don't get enough ventilation from the PS3. With good air going through them, they are extremely efficient. That said, the ZSSR5391A is only slightly less efficient - which is why it usually ends up overheating and cooking itself to death.
      Please, find whoever suggested that and tell them they are a moron (or if you want to be more polite, tell them to not give advice when they don't know what they are doing/talking about).
      The APS226, APS227, and ZSSR5391A units are rated for 32A on the 12V rail, while the APS-231 is rated only for 23.5A. So no wonder at all that the consoles shut off when using an APS-231!
      stth15r06fp
      Datasheet:
      https://cdn.badcaps-static.com/pdfs/...da89bf3935.pdf
      That's likely the PFC diode. 15A, 600V, 200 ns, 1.4V Vf drop. If you can a diode with the same specs but lower Vf, you might save yourself a little bit of heat.
      21n50c3
      Either PFC stage transistors or main PS chopper (or both - one for each, that is... but I doubt it. There should be a few more MOSFETs somewhere on primary side.)
      Again, if you can find a MOSFET with the same voltage, current, gate charge, and other important characteristics but lower Rds_on resistance, you will improve efficiency a little.
      06CN10N
      Synchronous rectifier MOSFETs (used in place of conventional schottky diodes on the output in order to improve efficiency - which they really do). Just as with the 21n50c3, if you want to improve efficiency, you want MOSFETs that have the same ratings but just lower Rds_on. Good luck. These are (IIRC) pretty good parts if you ask me.
      FCH10A15
      5V standby supply rectifier. Don't bother with this one, you probably won't gain any significant efficiency.
      My suggestion for you (if you really are serious and have the equipment, time, and gain the required knowledge to hunt down equivalent/more superior MOSFET - I know I don't) is to probe the PSU with a thermocouple as it's running and see which side/parts are the biggest offender when it comes to heat, then look for better replacements. However, what I think you will find is that these PSUs will run equally miserably hot everywhere inside all due to poor ventilation in the PS3. But that's just my 2 cents on this.
      • madan1
        Modding HPF filter
        by madan1
        Hi everyone.
        Recently scored a dead amp from a mackie srm1801 subwoofer and after fixing it, now I'm thinking about a home cinema/party subwoofer project.
        Most likely I will use a 15" JBL woofer, which I already have and a diy box.
        After reading the mackie user manual, I noticed that it has a 40hz HPF (labeled as "36Hz BUTTERWORTH HPF" in the SM) to protect the speaker from low frequencies. Indeed this seems to be good idea for the intended usage - professional music subwoofer, but bad for movies, where one would expect to "feel" the SUBwoofer....
        09-24-2025, 02:06 PM
      • tay147895412
        HP EliteDesk 705 G1 mini request for bios modding
        by tay147895412
        Hi, I have an HP EliteDesk 705 G1 mini.
        Model: HP EliteDesk 705 G1 Desktop Mini
        Processor: AMD PRO A8-7600B
        Motherboard PCB Marking: "APCB M3 94V-0" / "NPGC N-150TL"
        BIOS Chip: Winbond 25PE20VG (2 Mbit SPI, 3.3V, 8-pin SOIC) and MX25L6473E 64Mbit (8MB), SPI NOR, 3.3V, 8-pin SOIC
        Could someone help me with my bios , request:
        unlock MPM/DMI with a BIOS patch/mod , dc tay42069 if someone could help me pls
        Im gonna leave down below my working bios, if someone could mod it so it has the mpm...
        07-02-2025, 02:23 PM
      • lapot2
        The Best and Fastest BIOS Flasher for Modding Under $2
        by lapot2
        Recently, the Raccoon Flash Explorer programmer has appeared.
        It allows you to flash BIOS chips from any device without installing programs and drivers, and also very quickly make small changes without a long rewrite of the entire memory to change a few bytes.
        Very easy to use and intuitive, even a housewife can handle it.
        You can use absolutely any system binary file editor (HxD, WinHex, etc…) on any operating system, the possibilities are not limited by the ugly built-in editor like other programmers.
        It has full cross-platform support, works...
        04-21-2025, 09:37 AM
      • alpersen
        Modding, adding usb/c audio pcb to laptop with faulty sound card/chip, Lenovo L340
        by alpersen
        Hello
        After months of trying I gave up my laptops sound card. I plan to solder a sound card on pcb inside my laptops case, probably connecting to usb ports inside. Do anyone has an experience to recommend pcb type audio/sound card suitable installing inside a laptop? Probably should have some type of amplifier for connecting to internal speakers ( speakers ).
        Thank you
        11-19-2023, 09:34 AM
      • kulokutoys
        Bios modding for Newer NVME support
        by kulokutoys
        Device: Laptop
        Brand: Unknown
        Model: PD5D
        Board number: DAPD5DMB8C0 Rev. C
        Request: Repair/Edit
        bios is working fine, this laptop uses only and NVME ssd for storage. old NVME was broken and tried to replace not most recent nvme but wont detect on booting. it can format on windows installation but wont boot on windows. it can boot using clover boot. does anyone know how to edit the NVME driver on this bin so it can enable recent NVME ssd to boot
        05-09-2023, 08:31 PM
