Cap Value : Xbox One S PSU Model : N120A001L Rev:0.3
    Hi
    I need the value of C102 .
    Briefly : Blown Fuse . In-Series lamp lights fully = short on Hot Side - Bridge DC Holes are shorted !. Bridge OK out-of-circuit. Chopper Mosfet and Diode - OK. D102 ( T4 Diode ) measures In-Circuit 0.041V both ways but Normal outside. Other caps / diodes..ok. Short remains Haarg .
    BUT ! , when C102 Cap ( between Main Cap legs , it doesn't show as I took it out for easier access ) was taken out - short is gone .
    Thanks a bunch
    Are you asking for the one you marked in red arrow ? as i think it is actually C101 not c102 . I have not worked on the xbox but will try to look.
      Here is the datasheet for the chip on your power supply, there is schematic but unfortunately no values were on there
        Thanks !
        Unfortunately I deemed the PSU : Not fit for use.
        I replaced the marked cap with a similar size cap , for testing .
        The PSU worked fine with no load.
        Customer installed and after half an hour of work , with software update , it blew 3rd time ! ( He put new C102 and it blew again so he brought to me )
        Checking the PSU I found the same short , on the Bridge's DC pins , removed and short remained , BUT C102 was fine !
        Since the PSU is cheap , it makes no sense to risk the Console with a repeated fail .
