Oculus Quest 2 eror
+ More Options
Posts
  • tehmatix
    • Nov 2012
    • 174
    Oculus Quest 2 eror
    I got an error "System Alert high temperature" in 7s after boot. When the power button is pressed, the logo appears and after a few seconds the pairing code appears. After a second, the error message is displayed
  • croupier36
    Philips 32PFL5605H/12 issue with displayed colors
    by croupier36
    Need help with this unit...looks like the colors are not displayed correctly....not an expert, but looks like something wrong with the GREEN...have attached the photo of the 'home menu' and the recorded video of the Demo video that's on the TV for viewing/testing.
    Where should I look for faults? Everything else looks/works ok.
    BTW...have upgraded to the latest FW/SW version, but nothing changed....
    11-09-2024, 11:07 AM
  • groomit
    Meta Quest 2 not turning on - pulsing amp draw
    by groomit
    Hi
    Following problem regarding a Quest 2 I got with broken USB port and "not turning on".
    After replacing the USB/Audio port + cable the Device still refuses to turn on. A USB multimeter is showing a pulsing amp draw ranging from 70 mA to 1.2 A and back.
    All obvious caps measured good (no short).
    A visual thermal inspection showed two ICs glowing up also pulsing.
    One was a Qualcomm PMIC PM8150B which I suspected to be the culprit. But replacing it with a china-replacement made no difference.
    The other one I can't identify. It looks like...
    04-10-2024, 03:08 PM
  • Mc_Millian
    Toshiba 50lf711u20 fire tv remote not pairing
    by Mc_Millian
    I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
    The Tv model number is: 50lf711u20 Rev B.
    I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
    I've tried 3 different remotes which should be fully compatible with this TV.
    Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
    The power button, along with the volume,back,select, and directional...
    04-07-2022, 12:15 PM
  • cmonkey
    Zenith Z50PJ240 - White Screen with 'Power Only' displayed
    by cmonkey
    Turned on my lovely plasma and after about 30 seconds the screen below showed up. None of the inputs are responsive, just the red light flashes when I push it. Remote doesn't work either. To turn it off I need to unplug it and when I plug it in again it turns back on to this screen.
    I only found one reference to this issue with a different model but it didn't look super reliable. Only mentioned a 'main board fault'. The main board for this one is on ebay for $34 so might need to go with that.
    Anyone seen this before?
    Thinking about it some more, it happened...
    05-19-2023, 01:01 PM
  • Ierwin
    Philips 58PUS7805 Menu working but no/weird picture from video sources
    by Ierwin
    I got a 58pus7805 that shows some weird behavior.
    The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
    However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
    I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
    I managed to install the latest official firmware by holding the control button while plugging...
    03-10-2024, 12:50 PM
