Hello
I have been on a bit of a re-capp'ing adventure of late.
I have replaced the capacitors in
Sega Mega Drive model 1 VA6
Sega Mega CD model 1 (x2)
Sega 32X (x2)
Sega Genesis 2 VA2.3
I now have the case of the guilts as I have used cheap capacitors (JackCon etc).
While they work fine (the SMD caps in the Sega/Mega CD model 1's had leaked) I would like to re-visit these and replace with decent capacitors, I am thinking Rubycon or Panasonic. Also thinking of getting from Element14 vs eBay as
1/They SHOULD be genuine and
2/The price difference is about the same
3/No waiting 3-4 weeks for the capacitors.
Now my question extends to which series of capacitor should I use?
For example we have for Panasonic series AM (13cents each) up to GA (82cents each).
I am thinking of getting the middle cost option say AD, FC or M series.
Is this the right train of thought? Anything has got to be better than what I foolishly put in there. I should have known better as I worked as an Electrical Fitter for nigh on 10 years building circuit boards. Not in designing and spec'ing hence the questions.
Thank you Pete
Sega 32X (x2)
Thank you Pete
. But in the meantime I have 4 Capacitors that need immediate replacing each rated at 16V 3300uf and 105deg. I saw a break down review You Tube video where the host suggested that the 35V Capacitors were a better choice for manufacturers to use. Another video suggested that replacing capacitors of higher Voltage is fine but that the 3300uf rating should be kept the same. Can someone please clarify what the functional benefits...
