cap juice+high voltage=fire
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    this is a monitor from a swi prototrak .
    2 caps spilled their guts and the juice ran down under the flyback.
    these units are well sealed when the mounting arm bolts are in.still stunk up the customers van and i could smell it when i came in.it was still closed up and it stunk up the store and warehouse!
  • japlytic
    • Oct 2005
    • 2086
    Re: cap juice+high voltage=fire
    How old is it, and what are the brands of electrolytic capacitors?
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Al El cap electrolyte is very conductive.
      PeteS in CA
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        the worst leaker was a teapo.
        the rest are eci?
        these were made in 86 and run 24/7 in a sealed up hot box so its not if but when they will die.
        i get a ton of these units in for total rebuild.machine shops run them till the smoke comes out.
        • dragometin
          Hitachi 40HYC42
          by dragometin
          TV Model: Hitachi 40HYC42
          Power Supply: 17IPS71
          MainBoard: 17MB95M
          Panel: VES400UNDS-2D-NO3
          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
          Is there any variants on 17IPS71 power supply's?
          UART output pins 10 and 12 on scart connector:
          Code:
          12:24:04.595
          08-08-2024, 05:53 AM
        • vbogoev
          Lenovo S6000 won't turn on. Data recovery needed.
          by vbogoev
          Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
          Code:
          [PWRAP] pwrap_init_preloader
          [PWRAP] pwrap_init
          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
          [PMIC_WRAP]wrap_init pass,the return
          06-20-2023, 06:36 AM
        • EdwardGeo
          Macbook Air A1370 820-3024 CPU init and VCore missing
          by EdwardGeo
          All voltages are okay, even a thunderbolt boost is reacting on power request by cortex. Spi rom is read by pch, All_system_is_okay (mean the signal 3.3v by smc is present). But CPU won't request voltage from Max buck converter to power up VCore voltages to start the CPU. CPU and pch is getting warm. So there is no SVID and SVCLK data exchange. A lot of info on the web declare the TON signal failure on 2 pin of Max controller, and it has 90.2K, the voltage drop on power on, down to 0.35v. whrlen the system is off, then voltage on pin 2 is 8.4 volts.
          Btw forgot to say, all voltages...
          06-07-2023, 03:10 AM
        • yaya3gmax
          Laptop Power Issue – Works on Battery, Fails on Adapter Load
          by yaya3gmax
          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
          Symptoms:
          • Laptop works normally on a pre-charged battery.
          • Battery does not charge when adapter is connected.
          • Without battery:
            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
            • Speakers “pop” when power cut occurs indicating harsh sutdown.
            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
          08-21-2025, 07:16 AM
        • battery.12v
          SAS programing ec 256kb issue
          by battery.12v
          hello everyone i have a SAS IO programmer, i want to flash with it ITE-5570-256 version, its detected i can read and write but i cant specify the size to 256kb, it akways tell me its 128kb and when it read and write its just reading and writing 128kb,
          KB_pins=32 FLASH=256 LEFT DOWN 1MM PD0=26 PD1=22 PD2=20 PD3=15 PD4=19 PD5=23 PD6=16 PD7=18 BUSY=29 STB=21 AFD=32 INIT=25 SLIN=24 KSI4=28 KSI5=27
          Soft version --> 6.8.6855.234
          Mode selected --> ITE (IT8XXX)
          FTDI driver version 21236
          Version FW JIG M328_EPM240_v34...
          08-26-2022, 07:10 AM
