PS3 Disc Motor
  • Peter9DO
    • Dec 2011
    • 277
    PS3 Disc Motor
    Does anyone have a very good knowledge on PS3's optical drive and maybe a spec sheet of it all? I have a KEM-410CCA. Thanks!
  • Junior††
    PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
    by Junior††
    Good Afternoon fellas,
    Issue:
    Disc is showing as not supported when a disc is put in.
    Here's what I've done, you can skip this if you just wanna know the question:
    - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
    - reflowed the disc drive connector
    -reflowed the chip in question (shown on image)
    - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
    Question:
    I...
    02-19-2025, 12:48 PM
  • juergenb
    Nescafe Aeroccino, still fails with new Motor (red flashes only once)
    by juergenb
    i am asking for some Help.
    I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
    The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
    So i got a few of these from Banggood.
    I swapped the motor and now i have a new fault condition.
    In a working Frother you would press the start button, it will light red and work for a few minutes.
    If you press longer it will light blue and just mixup the milk.
    With the new Motor it just starts...
    03-23-2021, 11:24 AM
  • sbt123
    charnwood w821 mini wood lathe motor problem
    by sbt123
    hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
    10-27-2024, 03:43 AM
  • d00m178
    Philips toothbrush 4100 (HX369BK) - motor getting hot
    by d00m178
    trying to fix Philips toothbrush 4100 (HX369BK)
    The battery started draining quickly.
    After disassembling it, I discovered that the motor gets very hot when brush is off, which is apparently causing the battery to lose charge.
    The motor is connected to contacts M1 and M2.
    When I turn on the brush, 0.4V appears on these contacts, and the motor starts running as expected.
    But when I turn off the brush, the voltage changes to 3.8V—exactly the same as the battery.
    The motor gets so hot you can't touch it. And after 5 minutes, the battery drains to 0V.
    (To...
    11-12-2025, 03:11 PM
  • ahmedtou
    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
    by ahmedtou
    help me please
    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
    I will share all the details with you, including the disc information.
    Code:
    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
    Current Profile: BD-R
    Disc Information:
    Status: Empty
    State of Last Session: Empty
    Erasable: No
    Free Sectors: 12,219,392
    Free Space: 25,025,314,816 bytes
    Free Time: 2715:27:17 (MM:SS:FF)
    Next
    08-27-2025, 08:49 AM
