Emerson CKA1000 - Time signal clock radio - dried cap
  • xrror
    • 34
    Recently got an old Emerson clock/radio working again by replacing a capacitor in it. This is one of their "Radio Shack catalog" radios of yesteryear, where it has overkill features you'll never use (seriously, who needs four alarms?) but it DOES make a nice digital clock, since it sets itself using the Atomic Clock signal.
    So if anyone else has an old Emerson CKA1000 kicking around still (it's the silver one) and it starts resetting itself don't throw it away just yet. Mine would work until the house A/C kicked on... i guess the voltage drop was enough. But according to other posts it just keeps getting worse. The usual badcap syndrome right?
    this guy nailed the problem here, nearly six years ago http://www.fixya.com/support/t144760...uously_flashes
    To summarize replacing capacitor C554 inside fixes it. On my clock the dead cap was marked 1000uF 16v JACKCON. It looked fine, except all of the hot glue around that area of the board had turned black which was suspicious. I don't know if it was the capacitor itself, or if that area of the board just gets baked. I put in a random 2200uF 25v I had in my junk bin and it seems to be working... at least it hasn't reset for a day now, which is a massive improvement.
    And wow, thankfully this capacitor is on the "top board" when you open the clock, so you can just snip it off and run some wires for your replacement cap. There are literally 4 boards sandwiched together inside of this thing (in a depth of 2 inches) with MANY soldered interconnects. It would be a nightmare to disassemble it completely. Or I should say, to reassemble it with the intention of it working again.
  • shelby5041
    clock radio / radio lifespan?
    by shelby5041
    hi
    ive got a modern digital clock radio approx 15yrs old
    my question is how long can a clock radio or a simple radio last ss farcas operating hours?
    since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
    the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
    it uses very little power just a few watts i would imagine that may have something...
    09-14-2024, 03:30 AM
  • UserXP
    Vintage SONY Digital Clock Radio ICF-C12W no audio
    by UserXP
    Dear all,
    I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
    i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
    My question is, do you know of this brand of capacitors and how bad are...
    07-21-2025, 08:35 AM
  • littlejohn
    Emerson clock radio transformer
    by littlejohn
    Hello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
    08-30-2023, 07:13 PM
  • TinkerTron
    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
    by TinkerTron
    Hey everyone,
    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
    Instead, here's what's been bugging me so far:
    The schematic...
    03-06-2025, 02:03 PM
  • ClockChip
    GE 7-4643A Clock radio - Is this a common pictogramme for 9-volt battery backup on appliances?
    by ClockChip
    I came across this sticker recently:
    (It's from a 1980s GE clock radio - the model number is at the bottom left.)
    I worked out the top pictogramme (indicating a 12/24 hour facility) and bottom pictogramme (120v or 220v mains power) fairly quickly. But the middle pictogramme...ah. That one left me baffled for a time.
    (I won't say how long, exactly, because it would be too embarrassing.)
    Eventually, it dawned upon me that this was a pictogramme to indicate a 9-volt battery backup facility.
    My question is: has anyone...
    08-27-2024, 09:02 AM
