Playstation 3 PSU(not reading 12 volts)
  • Amraks
    • Nov 2011
    • 725
    I'm only getting 11.9 volts, off the psu I bought off ebay not working.
    I'm just wondering what components usually go in these?
    I have also notice a high pitch fizz when you turn it off.
    at the back of the ps3 unit.
    Thanks.
    Re: Playstation 3 PSU(not reading 12 volts)
    11.9V is fine... mine read 12.05V (a while ago I tested it)... probably fine anywhere from 11.6V to 12.4V like a standard ATX.
    • MisterAIL
      PS5 digital / No Power / No Beep / Good power supply
      by MisterAIL
      Brought a non functionnal PS5. Apparently only a bad PSU...
      No beep, nothing.
      After some tests i found this :
      - PSU is fine (12 volts stable)
      - 12 volts line is shorted
      - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
      - By the way, nothing change. No signal, no power, no beep.
      Mesuring all rails with my workbench psu (12 volts input)
      - 0.00 amp drawing
      - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
      03-12-2024, 03:24 PM
    • Mcfeetroy
      Fishing bite alarm drains battery
      by Mcfeetroy
      Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
      08-01-2025, 03:52 AM
    • BTubbs200
      Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
      by BTubbs200
      Dell Latitude 5420 P137G
      Board: LA-K491P REV A01
      I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
      Board seems to have no shorts, all power rails are fine and show high resistance.
      When charger is plugged in, voltage is present in 3.3V rail but absent in others....
      01-24-2025, 08:15 PM
    • stylishconsultant
      un60j620dafxza - Samsung No Display Problem
      by stylishconsultant
      Hi All,
      Need help.
      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
      09-04-2024, 03:26 AM
